Yeah I use that and I stopped updating my Facebook because it stopped working. This is the Facebook version I'm on.
Nope, and at 8pm tonight android system started drinking my battery. It's dropping like crazy now. Earlier today it was going down at a normal rate.That isn't normal..
Lol now I see it. SOT is 2 hrs at 48%It is there. Android System isn't too high, higher than mine is normally. I've seen AS up to 20 and 30 percent.
How many hours of screen time do you have?
All are off under WiFi. Today I've been texting people on messenger, facebook, insta, and snap chat. Nothing major like live streaming video or anything, no gaming either.Hmm.. 2 hours isn't that good for what you have been using.
What kind of stuff have you been doing on the phone?
First, but f you do not have GSAM installed, go to the Play Store and download it.
Under WiFi and advanced, do you have all of this turned off like I do?
Will do! Thanks so much for trying to help me find out what's going on, I appreciate it! Thing is, when I got this thing in September android system & os were fine and got about 5.5 hrs of SOT total until November and then android system and os started going nuts.Ok.. Set GSam to keep up with "Since last full charge". Charge your phone before bed, unplug it, let the phone run through the night and then through the day. Then I want you to post your battery stats page again and the screenshot of the GSam page.
Just use your phone as normal, don't top off the charge during the day, I want to see all the stats on one charge.
Since the week before last of September. I had this dead on same problem with my galaxy s5, it also stayed awake in safe mode. I even had a software reflash done at best buy and nothing. Since then I gave it to my brother and guess what? Android system and os are now behaving... I do not get this at all.Oh... In safe mode too? That is a problem.
How long have you had the phone?
I have gotten updates, but the issue didn't start after the last update which I believe was in October. Not so sure.If it wasn't in safe mode, I would say it is an app causing it.
You should have had some updates since you got the phone.. Hasn't AT&T released updates? I've gotten an update every month.
