Originally Posted by
Yuriy Romanov Still can't decide what I want to upgrade my Note 4 with.. Since there r 2 phablets now from Samsung but difference is s-pen that I never use.. Same screen size and quality. Same camera, processor and capacity... Only what I like more abt Edge+ is curved screen.. Have 1 week to decide
The differences are really simple actually.
Edge+ is more expensive than the Note 5. It has a curved screen which the Note 5 doesn't have. Software features includes people's edge (swipe in for favourite contacts), and apps' edge (swipe for app shortcut).
Note 5 has the S-Pen.
If the S-Pen isn't useful to you, then you would have to decide if the curved screen on the Edge+ is worth the extra dough. Though I would say to try the Note 5's S-pen features first. Personally they are extremely useful to me after I learned how to utilise them properly. Screen-off memo, action memos, the ability to doodle from time to time. I won't even give a second look at the Edge+ even if they both cost the same, simply because it doesn't have an S-Pen.
