What weather/date widget are you using?
What weather/clock widget is that?Constantly switching between these two. Nova Prime and Stock. I try to keep it clean and simple but can't make up my mind. I love both to be honest.
Dr Footie, I'll let someone else answer in more detail. But, I will say from my understanding it is merely a 'button' to maneuver within the OS (the simply version).
This may help a little:
http://forums.androidcentral.com/lg-g4/571342-stock-ui-nova-prime.html
Dr Footie. The Launcher is simply the application that acts as your homescreen and app launcher. Yes there are a bunch of them, some of them can really change the way your homescreen looks and works. Some like Nova are similar to stock or OEM launchers but offer much more customization options. Nova really is good. If you want to try it out its free and there are some features that you can get with Prime that are nice.
Sent from my SM-N920V using Tapatalk
Dashclock... still
//images.tapatalk-cdn.com/15/08/27/ee8383a382df27874043bff8a0d16251.jpg
Represent!Thank you for the reply. Once I get my phone today I'll spend some time setting it up and maybe get Nova going to play around with in the next couple days. I'll post a pic if and when I get that rollin'. Thanks again.
I see now you're from Fort Payne... you're right up the road from me. Guntersville!
Nova Prime. Banded Icon set with 6 on bottom. Set home button to launch app drawer in Nova settings and hide status bar with swipe up gesture to show it. Wallpaper from an icon pack (can't remember which one.) Dashclock widget with some extensions.OMG. WHAT Launcher are you using? It's so BlackBerry 10 nostalgia to me, which means I have been missing that type of homescreen. Please tell me what you use.
