1. Sammuel1973's Avatar
    I'm warming up to the Note 5 more each day, but unless anyone can help, are these features really gone?
    Hot Keys: assign text shortcuts to the number keys, especially handy for long usernames and passwords.
    Music voice commands: no more "stop/pause, play, next, volume up/down" while stock music app is opened.
    Music shortcut: no longer on the lock screen or in sleep mode, but still can be found on the toggle pull down.
    Read notifications out loud: handy when you're cooking or hands are not free.
    Multitask/window: no longer can read/reply to emails and text messages without stopping non-compatible video streaming apps like ESPN, Mobdro, etc.
    Attached are pics from my Note 4 as reference.
    ETA: I have TMobile
    Attached Thumbnails Features missing on Note 5?-1440176497639.jpg   Features missing on Note 5?-1440176508785.jpg   Features missing on Note 5?-1440176667735.jpg
    mango1228 likes this.
    08-21-2015 12:05 PM
  2. anon(5630457)'s Avatar
    Music voice commands: "stop/pause, play, next, volume up/down" while stock music app is opened.
    I do not see "hot keys" on my Note 5 but there is an option for text shortcuts, where you can create shortcuts for frequently used phrases. I'm not sure if that is the same thing.
    I do not see an option where notifications can be read aloud.
    08-21-2015 12:28 PM
  3. karsdroid's Avatar
    music shortcut still on the lockscreen with note 5
    08-21-2015 01:00 PM
  4. ProudArian's Avatar
    I do not have the Read Notifications option on my Note 5 either. I have a Verizon Note 5 ( who are known for removing USEFUL features)....
    It is possible that it is listed under another menu option. A lot of stuff has been moved around on this phone.
    08-21-2015 01:05 PM
  5. Sammuel1973's Avatar
    Hmmm, I just tried again, but the shortcut is only visible on the pull down toggle, but not on the lock screen. So when I press the power button on and off, the shortcut is missing on the lock screen. The Note 4 has it on both pull down toggle and lock screen as shown in my pics.
    08-21-2015 01:07 PM
  6. Sammuel1973's Avatar
    Thanks...yeah, I already tried the Text Shortcuts, but Hot Keys work a bit differently and better, almost like assigning the long pressed number keys for speed dialing. Text Shortcuts use the predictive text area when you type, and it doesn't work with passwords.
    08-21-2015 01:16 PM
  7. karsdroid's Avatar
    Hmmm, I just tried again, but the shortcut is only visible on the pull down toggle, but not on the lock screen. So when I press the power button on and off, the shortcut is missing on the lock screen. The Note 4 has it on both pull down toggle and lock screen as shown in my pic.
    08-21-2015 01:21 PM
  8. Sammuel1973's Avatar
    Karsdroid. Sorry, forgot to post pics.
    Attached Thumbnails Features missing on Note 5?-1440181275139.jpg   Features missing on Note 5?-1440181295364.jpg
    08-21-2015 01:21 PM
  9. karsdroid's Avatar
    i am on verizon...
    ok so here's what im finding.....if the music is playing it shows up per my pic above, on the lock screen. if i pause it there the screen relocks at some point and if i turn the screen right back on it will still be there, but if i leave it paused and the screen off for an amount (not sure how long it takes) of time it leaves the lock screen and the pull down notification shade. so i guess as long as i keep the music rolling no problem but once its paused i'm going to loose the ability to start it up again on the lock screen.
    08-21-2015 01:41 PM
  10. Sammuel1973's Avatar
    i am on verizon...
    Thanks for sharing your experience. I have TMobile, so maybe my experience is different; any other TMobile users can confirm with their new Note 5?
    08-21-2015 01:47 PM
  11. sprinter51's Avatar
    has anyone figured out where to turn on the "Read Notifications Aloud" feature?
    12-31-2015 10:35 PM
  12. sprinter51's Avatar
    have you figured out how to find this feature?
    12-31-2015 10:38 PM
  13. JohnnytheK's Avatar
    Hands off setting, I found it more annoying than helpful so I turned it off.
    01-01-2016 12:30 AM
  14. Sammuel1973's Avatar
    This Note 4 feature is not on the Note 5, but there's an app that works even better and more comprehensive. Some say this type of feature can be annoying but with this app, Voice Notification: Shouter, you can customize how or when the notifications are read outloud. I have my BT headset on all the time, so I get these notifications read outloud to me while my phone screen is off and without anyone around me hearing them. So convenient!
    01-01-2016 09:06 AM
  15. pbickel's Avatar
    In your notification settings are you sure the music isn't check to hide on lockscreenFeatures missing on Note 5?-uploadfromtaptalk1451661896925.jpeg?
    01-01-2016 09:25 AM
  16. Sammuel1973's Avatar
    In your notification settings are you sure the music isn't check to hide on lockscreenClick image for larger version.
    Thanks, looks like TMobile has it working since the last update. And no, I never have that checked.
    01-01-2016 09:38 AM
  1. Faint blue tint on bottom half of screen
    By djroy03 in forum Samsung Galaxy S6 edge
    Last Post: 08-24-2015, 09:21 PM
  2. How do I video chat on my Venue 7/8?
    By AC Question in forum Dell Venue 8 7000 Series
    Last Post: 08-22-2015, 01:46 PM
  3. Replies: 2
    Last Post: 08-22-2015, 01:41 AM
  4. Wallpaper on a Samsung Galaxy S5
    By Marioclement23 in forum Samsung Galaxy S5
    Last Post: 08-21-2015, 05:38 PM
  5. Replies: 2
    Last Post: 08-21-2015, 02:25 PM
