Does the note 5 have the loose home button that makes clicking noises when lightly tapped on? (Not pressed all the way). I'm planning to get one today but worried since it's got the same design as the s6 and have the same home button issue as well
My home button is loose. The guy at best buy told me there supposed to be. But I'm calling bs on that one. I got an att model. My galaxy s6 button is loose too with absolutely no issues ever.
Seems fine on mine and I only bought it today. I just wished the finger print scanner would 'unlock', and take me to the home screen. I must be doing something wrong.
I dont think it will come off loose. I took apart my S6 and through bunch of testing i found out that the two tabs that hold the button in place taps against the front panel. If you tap the left side of the home button the right tab will lift up and hit against the front panel and vise versa.
Google 'Galaxy S6 home button replacement' and have a look at the home button part and you will see that there are two tabs that stick out on the sides. I'm guessing the note 5 has the exact same design on it.
After putting a very thin padding on it with a double sided tape the clicking noise was gone.
