petereffendy
I use ume tempered glass, it has a bit halo near the home and back button. But it's much better than note 4
I am using Zagg and it's flawless
For me, I have learned through the months no need to put any screen protectors on as long as I don't drop the phone. The type of gorilla glass is quite antiscratch resistant as long as I don't put my keys in the same pocket. I have used many types of tempered glass screen protector, they eventually fall off or have microscopic scratches.
Sure... So long as you don't ever drop the phone or use something hard to scratch the screen then you will be fine. Similarly, you wouldn't need a case either.
For those of us who want to help protect against accidents, a tempered glass screen protector expecially at a buck is a good and low cost investment
Sent from my Verizon Samsung Galaxy Note 5
Depends on how careful you are. I dropped my note 2 a few days after I got it and it had a scratch that caused a rainbow glare out of it. After that I always used a screen protector.I disagree. I went without a screen protector on my Turbo and it got a few microscratches. Granted, they weren't noticable unless in direct lighting but it still happened. I always kept my phone in am empty pocket while my keys and wallet were in the other one.
I guess it's not a necessity but I for one despise microscratches. Granted, I think my Tempered Glass has the same kind and I don't notice them during daily use. I don't mind though since I have the option to pull it off and apply a new one if necessary.
On a side note, I've never had one fall off. What brands had this issue?
My skinomi looked similar before I pressed it downI bought from Amazon Jetech Tempered Glasscrean for $7.99
//images.tapatalk-cdn.com/15/09/15/b9342d423aed1f2bb49c2d3f1b5b59d1.jpg
Unfortunately the edges don't look good
//images.tapatalk-cdn.com/15/09/15/b9e672f641d3f147d3fc8669c6d1cc41.jpg
Sent from my SM-N920V using Tapatalk
Coolbo. After 3 weeks, the adhesive wore off.On a side note, I've never had one fall off. What brands had this issue?
For me, screen protectors are for antiscratches, not for handling drops; cases are for drops and antiscratches. There are flip/flap cases that are good without the need of a screen protector. I always have had cases to prepare for drops, not screen protectors. The appreciation and enjoyment without any screen protectors on the display are unparallel.Sure... So long as you don't ever drop the phone or use something hard to scratch the screen then you will be fine. Similarly, you wouldn't need a case either.
Of course, to each his own. But a quality tempered glass screen protector still gives me about 95% enjoyment which is good enough for me.For me, screen protectors are for antiscratches, not for handling drops; cases are for drops and antiscratches. There are flip/flap cases that are good without the need of a screen protector. I always have had cases to prepare for drops, not screen protectors. The appreciation and enjoyment without any screen protectors on the display are unparallel.
I have a zagg. There is halo and this blue tint sucks
Wow did you kill your brother in law?
