I am using Zagg and it's flawless
Sent from my SM-N920P using Tapatalk
On a white or black Note 5?
Wait 48? Lol they are just trying to get away from not replacing it. No halo is disappearing only some bubbles will vanish. With tempered glass if it's not on perfectly the first time it will never be.
If you are slightly off, shouldn't the halo only appear on one side? I tried 4 different glass covers from Amazon and every single one had halo around all sides of the phone.
I had this issue with my Note 4 but found the Icarez worked perfectly (then I found their 0.15mm version and it was even better!)
I'll have to go to ATT and see if their version is different from the one I bought at Best Buy. If its based on cuts I think the one at best buy is probably too large that the halo effect occurs on all sides. I just wouldn't want to waste their time at Best Buy if its something that cannot be fixed with their version of the Zagg product.
Does the BB Zagg use blue screen tech? This was an issue with the Zagg best buy sold for the s6, it would halo.
Best buy actually has their own version of the Zagg glass.
The ATT Zagg is flawless though.
Zagg would most likely not cut the protector differently. The Blue Filter should be the only difference because Zagg knew to cut the Glass short after the Note 4 issues.
