08-25-2016 02:31 PM
30 12
tools
  1. novice's Avatar
    On my Verizon phone (w/out unlimited data) if I turn on advanced calling to obtain data during a call I'm warned I will lose Caller ID. So I opt for caller ID.
    03-27-2016 08:15 PM
  2. aly koly's Avatar
    Hello
    I got a galaxy note 5 , and unlocked it, but still can't make any call, even though that I can use the data perfectly?!!?.
    Best regards
    05-02-2016 07:23 PM
  3. Trees's Avatar
    Hello
    Best regards
    Is your Note 5 a Verizon version? If not, may want to contact your wireless provider for help in activating voice and calling.
    05-03-2016 06:44 AM
  4. tungsten c's Avatar
    I am having the same problem now in sprint. I am trying to upgrade the phone but the S& wont do simultaneous voice and data. Do you know of any phone that will do that? MOTO, LG etc.. and why is it that they remove that from the phones? Connectivity is not that the main objective of having a mobile device?. Thanks
    08-25-2016 12:40 PM
  5. Climb14er's Avatar
    Hello
    Best regards
    I had to call Verizon Tech to activate the HD Calling and then toggle it on, in the Phone. Once this was done, both data and calling were enabled at the same time.
    08-25-2016 02:31 PM
30 12
  1. Replies: 5
    Last Post: 08-28-2015, 06:01 PM
  2. How do I get high 5 casino to work on my galaxy s4?
    Last Post: 08-22-2015, 12:56 AM
  3. Why won't my Note 4 sync with my vehicle Bluetooth?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 08-22-2015, 12:55 AM
  4. Verizon phone on ATT service plan: how can I fix a signal problem?
    Last Post: 08-21-2015, 09:46 PM
  5. Replies: 0
    Last Post: 08-21-2015, 09:03 PM
