05-14-2016 05:47 AM
92 1234
tools
  1. emad1995's Avatar
    Biggest battery drain is google play services that I have no idea how to get rid of.
    For me turning off these 2 things:
    1. Google now
    2. Location history
    Will take play services out of my battery stats. Give it a try and see if you get the same reaults.
    08-24-2015 01:11 AM
  2. sup3r1or's Avatar
    It sucks taht this is the only way. I actually use Google now for google voice search. Actually will OKAY google still work if I switch off google now? I have widget that came with stock Note 5 for google search on main screen and I use commands quite often, will it still work if I have google now OFF?
    08-24-2015 02:05 AM
  3. russel5150's Avatar
    1. Google now
    2. Location history
    How do you disable google now? Is it the regular google app?
    sent with my white Note5 with nonremovable back and no SDCard!
    08-24-2015 02:07 AM
  4. sup3r1or's Avatar
    Open google search app press 3 lines on the left go to settings, SHOW NOW CARDS press off and then Okay. Im not sure if I will loose voice commands and control if I do that, will try later.
    08-24-2015 02:45 AM
  5. russel5150's Avatar
    Okay thanks I just turned it off.
    08-24-2015 03:54 AM
  6. TheMatrix31's Avatar
    Is there a good replacement for quick traffic updates for "going home" if I disable Google Now? I love just opening my notification panel and seeing whether it's 30 minutes to work or 50.
    That's really what I use it for the most. And reminders but I can DL a separate app for that.
    08-24-2015 05:06 AM
  7. sup3r1or's Avatar
    Not that i know if and it wont integrate on this level. Maybe here maps but not sure.
    I wanted to ask if i diaable google now can instill use ok google and ask it to do things for me?
    08-24-2015 05:55 AM
  8. ThomaspHK's Avatar
    I have the same issue. Biggest battery drain is the cell standby.
    08-24-2015 05:59 AM
  9. sup3r1or's Avatar
    Im at 44% now with 10 hours off charger but only 2 hours SOT. How do people get over 5 hours is beyond me
    08-24-2015 06:54 AM
  10. sup3r1or's Avatar
    People please twll me ifnyou have smart on enabled in setting display that tracks your eyes?
    08-24-2015 06:58 AM
  11. tanson1011's Avatar
    I have mine off. I use an app called Screebl. It keeps your screen on depending what angle your phone is at. Totally customizable. Screen shuts off when phone is flat, or whatever angle you configured in the app.
    Battery life still isn't great if you're wondering if turning that off helps.
    08-24-2015 07:51 AM
  12. sup3r1or's Avatar
    So here is my stats for today not even close to 3 hours SOT but already down to 36%. People how donyou manage 5 hours SOT?
    Attached Thumbnails Standby battery drain-1440423105010.jpg   Standby battery drain-1440423117194.jpg
    08-24-2015 08:32 AM
  13. sup3r1or's Avatar
    SoT 2 hours 45 mins
    08-24-2015 08:32 AM
  14. Kelly Kearns's Avatar
    This is my standby drain, I just did the screenshot.
    08-24-2015 08:35 AM
  15. Kelly Kearns's Avatar
    If you had battery problems on a Note 4 you probably will on a Note 5, unless you change how you are using the phone.
    08-24-2015 08:38 AM
  16. Kelly Kearns's Avatar
    You don't have to have Google Now running to use voice search. I rarely turn Google Now and have always used Google search voice, sometimes using the widget that comes with the phone. Also I use "OK Google".
    08-24-2015 08:44 AM
  17. MedicD's Avatar
    Kelly how did you get your cell standby to be on for 10 hours but only connected for 2?
    08-24-2015 09:58 AM
  18. Kelly Kearns's Avatar
    That was just what it was when I unplugged it and went to bed and then picked it up this AM.
    08-24-2015 10:27 AM
  19. Michael Reshetar's Avatar
    I think your cell signal has a lot to do with the standby drain. I have a poor signal in my house. 1 bar at most. This causes standby battery drain. (at least I think it does)
    08-24-2015 10:33 AM
  20. Kelly Kearns's Avatar
    I have a signal booster in my house, so I have very good signal.
    08-24-2015 10:34 AM
  21. MedicD's Avatar
    I have 3/5 bars of 4g at my house, and about the same at work. I have a signal booster not setup, I suppose I could do that, but I think it's only 1x or 3g. Won't my phone default to the 4g it sees instead?
    08-24-2015 08:09 PM
  22. Kelly Kearns's Avatar
    Who is your carrier?
    08-24-2015 08:21 PM
  23. Kelly Kearns's Avatar
    If it is AT&T that booster is for calls, works well. T-Mobile is for calls and fast data.
    08-24-2015 08:23 PM
  24. MedicD's Avatar
    Vzw
    08-24-2015 09:41 PM
  25. Kelly Kearns's Avatar
    Oh.. Don't know how their booster works.
    08-24-2015 09:50 PM
92 1234
  1. Extended battery
    By Inmartol13 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 09-14-2015, 01:19 PM
  2. Galaxy S6 Frustrating battery life and overheating
    By sepandee in forum Samsung Galaxy S6
    Last Post: 08-27-2015, 08:54 PM
  3. Why is my battery draining to quick?
    By AC Question in forum Batteries
    Last Post: 08-27-2015, 07:32 AM
  4. How can I stop my Note 3 battery from draining?
    By Scott Crebert in forum Samsung Galaxy Note 3
    Last Post: 08-27-2015, 01:54 AM
  5. Replies: 0
    Last Post: 08-25-2015, 07:58 PM
