05-14-2016 05:47 AM
92 1234
tools
  1. hermeshidayat's Avatar
    My Note5 is somehow better than my Note4.the battery doesnt seem to drain as much as my Note4.standby or while using.
    08-24-2015 09:53 PM
  2. jlilnc14's Avatar
    This is my screen shot. Standby and Android system is highest. Normal? 4 hrs SOT
    08-24-2015 09:54 PM
  3. Kelly Kearns's Avatar
    Why is yours yellow? Do you have a bad signal?
    08-24-2015 09:56 PM
  4. James8561's Avatar
    My android system drains almost 40%! Is there any way to fix that? I already tried DU battery saver pro and it doesn't seem to help with android
    08-24-2015 10:25 PM
  5. jlilnc14's Avatar
    Not sure? It was green early today. Maybe it turned yellow after I restarted my phone?
    08-24-2015 10:38 PM
  6. Kelly Kearns's Avatar
    Mine is always green. The old one had a line under it showing the signal. A bad signal can drain your phone fast.
    I need to find out from Samsung what determines if it is green or yellow..
    08-24-2015 10:40 PM
  7. MedicD's Avatar
    Interesting find. Mine used to be green, now mine is yellow
    08-24-2015 11:48 PM
  8. sup3r1or's Avatar
    Turns yellow under 20% then red
    08-25-2015 09:22 AM
  9. Kelly Kearns's Avatar
    Ahhh.. Never had the graph match the battery before.
    08-25-2015 09:25 AM
  10. shook187's Avatar
    Strange I'm on the t-mobile variant of the note 5 and even though I have the phone on airplane mode with Wi-Fi calling on I still get high call standby drain. Isnt my radio supposed to be off when on airplane mode?
    Overall I have great battery life so I don't really pay attention to that number
    Sent from my SM-N920T using Tapatalk
    08-25-2015 09:33 AM
  11. Kelly Kearns's Avatar
    Airplane mode should shut off WiFi also.
    Have you just tried a cache wipe? I had an issue with answering a call when the pop up for a call came on the screen. I just did a cache wipe and that took care if it. Sometimes a cache wipe can take care of many issues and it doesn't reset anything, always worth trying.
    08-25-2015 10:04 AM
  12. shook187's Avatar
    You can still turn on WiFi while on Airplane mode.
    But no I haven't tried none of that other stuff
    08-25-2015 03:18 PM
  13. Kelly Kearns's Avatar
    When I turn on Airplane, it turns off my WiFi.
    08-25-2015 03:52 PM
  14. shook187's Avatar
    It turns it off but then you can turn it right on after airplane mode is on give it a try
    08-25-2015 04:45 PM
  15. Kelly Kearns's Avatar
    Interesting.. I thought the purpose of Airplane Mode was to keep everything off.
    08-25-2015 04:55 PM
  16. shook187's Avatar
    Airplane mode keeps the device radio off.
    08-25-2015 05:59 PM
  17. dpham00's Avatar
    Have you tried using wakelock Detector?
    http://forums.androidcentral.com/sam...-required.html
    Sent from my Verizon Samsung Galaxy Note 5
    08-25-2015 06:02 PM
  18. Kelly Kearns's Avatar
    I thought it did all though. I've never turned it on and used the phone for WiFi though. Good to know.
    08-25-2015 06:03 PM
  19. shook187's Avatar
    Try it, battery life is amazing
    Kelly Kearns likes this.
    08-25-2015 07:05 PM
  20. rgh718's Avatar
    My battery life is decent and I'm a pretty heavy user but around 4pm for 7am start I need a charge.
    08-25-2015 08:26 PM
  21. rgh718's Avatar
    I did see a case that had a extended battery and a sd slot. It was like $100 bucks. I'll find the site and post it
    08-25-2015 08:28 PM
  22. MedicD's Avatar
    On vzw with advanced calling on and airplane mode on I am unable to text or call
    08-25-2015 08:47 PM
  23. Kelly Kearns's Avatar
    Does Verizon have WiFi calling?
    08-25-2015 08:54 PM
  24. MedicD's Avatar
    I guess I thought that's what advanced calling enabled but maybe not
    08-25-2015 10:22 PM
  25. dpham00's Avatar
    No.
    08-25-2015 10:27 PM
92 1234
  1. Extended battery
    By Inmartol13 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 09-14-2015, 01:19 PM
  2. Galaxy S6 Frustrating battery life and overheating
    By sepandee in forum Samsung Galaxy S6
    Last Post: 08-27-2015, 08:54 PM
  3. Why is my battery draining to quick?
    By AC Question in forum Batteries
    Last Post: 08-27-2015, 07:32 AM
  4. How can I stop my Note 3 battery from draining?
    By Scott Crebert in forum Samsung Galaxy Note 3
    Last Post: 08-27-2015, 01:54 AM
  5. Replies: 0
    Last Post: 08-25-2015, 07:58 PM
