05-14-2016 06:47 AM
92 ... 234
tools
  1. dpham00's Avatar
    I guess I thought that's what advanced calling enabled but maybe not
    Advanced calling 1.0 is volte (voice over LTE).
    Sent from my Verizon Samsung Galaxy Note 5
    TheDonJ77 likes this.
    08-25-2015 11:27 PM
  2. sunnyoneva's Avatar
    In 8 hours I went from 100% to 68% with a bit of consistent use, and a bright screen...
    08-27-2015 05:59 PM
  3. Kelly Kearns's Avatar
    I think T-mobile is still the only one with WiFi calling and texting, though there might be apps to be able to WiFi text. I know AT&T is supposed to be getting it soon, not sure about Verizon.
    08-27-2015 07:34 PM
  4. erasat's Avatar
    I can be on standby for hours on both my S6 edge and S6 Active and they simply drain 1% every 4 hours or so with 2 Google accounts syncing all the time with tons of emails.
    With M release in a couple of months there will be a new feature called Doze that will help with just that, Standby time, but until then you can always download this great app called the same, Doze, it does basically the same but for most Android versions and not just latest one and for all devices running them, the good thing about is that it kicks off as soon as your screen turns off.
    Check the app here, https://play.google.com/store/apps/d...TmIce6eKn5nIgN
    08-27-2015 07:41 PM
  5. Kelly Kearns's Avatar
    I've installed this to see how it works.
    Are you familiar with Greenify? I used it on my N4 for a while and 10 hours of not touching the phone I would lose 1% and nothing would wake my phone except the apps I selected. Does this work the same, except it starts automatically when the screen goes dark?
    08-27-2015 07:45 PM
  6. erasat's Avatar
    Yes I've tried Greenify before and it's kind of similar on their goal, but the approach is little different and for some reason I never liked Greenify it always gave me problems with the apps I wanted to keep notifying, like Gmail and some others, I don't know why but the 2 times I tried it, it was the same. With Doze its very easy, jut add all those you want to keep notifying and running in the background tomnthe Active list and all the rest will stop using data after the screen turns off, and it has worked great so far.
    This and the Auto Stop feature that was fixed with 5.1.1 by Samsung, it's a killer combo.
    08-27-2015 08:10 PM
  7. Kelly Kearns's Avatar
    This and the Auto Stop feature that was fixed with 5.1.1 by Samsung, the combo is a killer.
    Auto Stop feature? I'm not familiar with that. I have noticed though that some disabled apps still have background data running, which is crazy.
    08-27-2015 08:18 PM
  8. erasat's Avatar
    Yes, check the other thread where I posted my tweaks and the original link to the S6 forum, you'll see there the details about the Auto Stop feature, but it seems that it may have been disabled by AT&T and Verizon, and there are other carriers in Asia that moved it to the RAM Management section. AT&T didn't even have it on 5.0.2 that is the latest version they have for the S6 variants (S6, edge and Active), so I don't really know with their 5.1.1 version for the Note 5 and Edge+.
    08-27-2015 08:23 PM
  9. erasat's Avatar
    Check this thread from July. http://forums.androidcentral.com/sam...ted-stuff.html
    08-27-2015 08:27 PM
  10. Kelly Kearns's Avatar
    Ok.. I can never open those details. It is there but greyed out and says, all apps have used a normal amount of battery..
    I have T-Mobile.
    08-27-2015 08:36 PM
  11. getbretweir's Avatar
    standby drain across Android is and always has been horrific. Google has started and ended project after project over the last 5 years trying to solve it, but somehow they couldn't figure it out. iPhone doesn't deal with these issues, and is light years ahead, but obviously there's a lot less moving parts so the task is much more difficult for Google.
    Improving standby drain by even 50% would make a monster difference in battery life. Think about how many times you look down and see 24% ... it'll be closer to 50% soon.
    Fortunately (and i realize this isn't breaking news, but hopefully it is for a few people following the thread) Google finally seems to have made significant progress and Doze has received positive feedback this far. M will be here soon enough, and unlike LP, I think it's going to make a dramatic improvement (despite the subtle changes) and be closer to what we originally expected from LP.
    I've been b*tching about standby drain since I moved in with my now wife 5 years ago. She almost never charges her iPhone overnight, and I see it next to mine 71% when I go to bed, 70%, maybe 69% in the morning. Meanwhile hop in the shower and when I head out to work I'm already down 5% .... Yeah, definitely hoping Doze works as advertised!
    08-27-2015 09:16 PM
  12. erasat's Avatar
    I have T-Mobile.
    That's weird, that was the exact thing that was happening before the 5.1.1 update, and it was stated that it was one of the things that was fixed on the released version, so I assumed that all the 5.1.1 versions, including the ones on the Note 5 and Edge + already had that fixed, it seems not, really weird.
    08-27-2015 09:24 PM
  13. getbretweir's Avatar
    question: one of the major features with M is permissions. so if I don't want to give out certain info to let's say Facebook, I'll have that option (which I will surely take advantage of).
    i would think the less info they're allowed to take, the less often things will be running in the background, which is another big drain. is that just wishful thinking or I'm I right about that? or do i just sound like a jackass and have no clue what I'm talking about!!
    08-27-2015 09:27 PM
  14. Kelly Kearns's Avatar
    I had my S6 Edge for like 3 weeks and I think I couldn't open that part on the S6E either.
    08-27-2015 09:30 PM
  15. Kelly Kearns's Avatar
    The other thing and what is causes the heads up notifications, the developer gets to pick the priority of their notification. So a heads up notification is the highest priority. I would also imagine if it is a high priority notification, it probably uses more resources also automatically. That is something we are supposed to be able to change.
    08-27-2015 09:32 PM
  16. erasat's Avatar
    I really don't know too much about Doze on M, other that what is common knowledge on basic info, but with the Doze app I know that if you don't add that app to the Active list it will shutdown all data traffic from and to it.
    08-27-2015 09:34 PM
  17. veasna toem's Avatar
    Hello everyone. I just picked up note 5 64gb version yesterday. I was very pleased with the phone and also battery life. However I left it in do not disturb mode at night it had 84% battery left or more. Woke up 6 hours later to 72% then another 2 hours later to 65%. Why is that? I don't have any apps running in background no downloads or updates. Anyone noticed that?
    05-14-2016 06:47 AM
92 ... 234
  1. Extended battery
    By Inmartol13 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 09-14-2015, 02:19 PM
  2. Galaxy S6 Frustrating battery life and overheating
    By sepandee in forum Samsung Galaxy S6
    Last Post: 08-27-2015, 09:54 PM
  3. Why is my battery draining to quick?
    By AC Question in forum Batteries
    Last Post: 08-27-2015, 08:32 AM
  4. How can I stop my Note 3 battery from draining?
    By Scott Crebert in forum Samsung Galaxy Note 3
    Last Post: 08-27-2015, 02:54 AM
  5. Replies: 0
    Last Post: 08-25-2015, 08:58 PM
