1. ProudArian's Avatar
    I have tried deleting the account and re-adding it and my work calendar still does not show up under the stock Calendar app. I never had this problem with my Note 3. Anyone else experiencing this?
    I have all of the approriate checkboxes clicked.
    08-23-2015 01:01 PM
  2. Connert's Avatar
    How about mail, contacts and notes? I'm assuming they are syncing correctly. What version of exchange is your company using?
    08-23-2015 01:38 PM
  3. ProudArian's Avatar
    Yes, all of those are syncing just fine. I'm not sure what version of Exchange they are using
    ..guess I will need to find out.
    08-23-2015 01:57 PM
  4. Connert's Avatar
    With the calendar in Month view, go to "more" in the top right corner. Select "Manage Calendars" and select the ones you want to see in the calendar.
    08-23-2015 02:25 PM
  5. ProudArian's Avatar
    I tried that and the Exchange calendar is not listed as an option.
    08-23-2015 04:29 PM
  6. Connert's Avatar
    Sorry, that's about as far as I can go. I'm using NineMail so the settings any further than this I'm unsure of what you are seeing. I would be looking all over the mail setup for calendar sync options. Good luck.
    08-23-2015 05:00 PM
  7. ProudArian's Avatar
    Thanks for your help.
    08-23-2015 08:53 PM
  8. barry99705's Avatar
    My note didn't have exchange services installed. Had to side load it to even add exchange to gmail. After that I had to go to app settings and uninstall the gmail updates, taking it back to stock, then reinstall the gmail updates. I get exchange email and calendar now. We're running exchange 2010 at work.
    08-23-2015 11:00 PM
  1. Quality control issues on Note 5
    By willypguy in forum Samsung Galaxy Note 5
    Last Post: 08-24-2015, 02:02 PM
  2. My HTC M8 is not charging, what could be wrong?
    By janith shehan in forum HTC One M8
    Last Post: 08-24-2015, 12:04 AM
  3. need help with Google search issue
    By beckybluecat in forum Ask a Question
    Last Post: 08-23-2015, 12:08 PM
  4. Replies: 0
    Last Post: 08-23-2015, 11:46 AM
