1. ThomaspHK's Avatar
    Hi guys,
    Would just like to get some input from other Note 5 users.
    Been using the device now for 2 days and to me it feel like it gets quite hot. Definitely hotter than my OnePlus One. It's not uncomfortably hot, but there's definitely some heat dissipation from the back.
    I'm not talking about heavy use or during charging where this kind of thing is expected. Even during normal light use like browsing the back is warmer than the sides.
    Let me hear your experiences.
    08-24-2015 05:52 AM
  2. mhettrich's Avatar
    I've not had any problems with this. My phone hasn't even gotten warm at any point yet. I haven't played any games yet though.
    Sent from my Note 5 using Tapatalk
    08-24-2015 06:23 AM
  3. GrungyNA's Avatar
    Zero heat for me. My LG G4 would heat up like an oven but not my Note 5.
    08-24-2015 06:38 AM
  4. ThomaspHK's Avatar
    Hmm. I'll keep monitoring it for the next few days. If it stays bothering me I'll go back to the shop. I remember it got better on the OnePlus One as well after some battery cycles.
    08-24-2015 07:42 AM
  5. ThomaspHK's Avatar
    Anyone care to do me a favour: install the cpu-z app and look at the temperature readings?
    Under light load I'm reading about 40-44° for the CPU.
    08-24-2015 07:48 AM
  6. GrungyNA's Avatar
    30° with almost no usage. I'll check throughout the day and post the highest temp.
    08-24-2015 08:06 AM
  7. Paradroid01's Avatar
    Well, it also depends on the all around temperature.
    08-24-2015 08:11 AM
  8. anon395528's Avatar
    yea, here in Las Vegas the last two weeks have been 105º+ daily....in my car I have to cover with a towel...but, my Note 3 was the same way. But, in my house, even on my VU wireless charger, I don't feel any exceptional heat.
    08-24-2015 09:41 AM
  9. jmy7213's Avatar
    Been using mine for a couple hours this morning. I just looked up my CPU temp in AIDA64 and its running around 95 degrees. I switched to to celcius to match yalls numbers and its at 36 degrees.
    Sent from my:
    Beautiful Note V
    64 GB
    Black Sapphire
    Sprint PCS
    08-24-2015 09:47 AM
  10. ThomaspHK's Avatar
    Yeah, I do live in Hong Kong, so temperatures are typically quite high. But even in nicely air conditioned spaces it gets somewhat warm to the touch. CPU z typically reads between low thirties and mid forties. Probably normal I guess.
    08-24-2015 09:59 AM
  11. ThomaspHK's Avatar
    Update: went to Samsung service centre and the guy confirmed something was not right. His English was not great but he said the "output was unstable". Whatever that means and I'm not sure what test he performed, it was behind closed doors. Anyway, I have an official report to take to the shop to get a replacement.
    08-25-2015 07:13 AM
  1. Replies: 3
    Last Post: 08-25-2015, 12:22 PM
  2. How to make people to hear me in a galaxy note 4?
    Last Post: 08-24-2015, 12:11 AM
  3. Android Auto and ATT Note 4
    By AC Question in forum Android Auto
    Last Post: 08-23-2015, 11:32 PM
  4. Note 5 memory management seems too aggressive.
    By samsungnian in forum Samsung Galaxy Note 5
    Last Post: 08-23-2015, 10:51 PM
