02-18-2016 06:37 AM
49 12
tools
  1. Jay G63's Avatar
    Thought it might be interesting to see if there was a color pattern for the wireless chargers people received that are not fully charging. I had in store credit with my 2 note 5 purchases and 1 chose 1 white charger and 1 black charger. The white one works flawlessly for my wife. When she wakes up in the morning she is always at 100%. I had the black one and about every 6 minutes mine would stop charging and the battery would drain. Found out the hard way the 1st night use. Have tried both phones on white charger vs black one with positive results for the white and negative on the black. Video taped it to show sprint so they would understand the problem and didn't just put it back on the shelf.
    So is the problem with black chargers only or did you get a bad white one?
    I exchanged my faulty black one for the last white one in house. Hoping for the best tonight.
    Sent from my SM-N920P using Tapatalk
    08-24-2015 06:54 PM
  2. stanleybb50's Avatar
    My black one has the issues. So add a black one to the bad guys...
    Sent from my SM-N920V using Tapatalk
    Jay G63 likes this.
    08-24-2015 07:14 PM
  3. sx4dude2013's Avatar
    I assume that most are black since they are the free ones. Mine is black and it sucks. every 5 minutes it stops charging.
    I ordered a new one today from Amazon. Hoping its flawless
    ladyc0524 and Jay G63 like this.
    08-24-2015 07:15 PM
  4. Jay G63's Avatar
    I didn't realize only the black ones were being offered in BB free giveaway.
    08-24-2015 07:23 PM
  5. dasupaman23's Avatar
    Yeah I've noticed my black one (free from BB) is having issues. I do have another one that I got from Amazon when I had my S6 Active. Going to use that tonight and see if it makes a difference tomorrow.
    Jay G63 likes this.
    08-24-2015 07:35 PM
  6. dridas's Avatar
    I bought the black one and had issues with it right away. I made sure I used a 2A charger and didn't use a long micro usb cable and that helped.
    I read somewhere to enable the daydreaming while charging and I have not had any problems since. Charges flawlessly.
    Jay G63 likes this.
    08-24-2015 07:58 PM
  7. purpleclad's Avatar
    I have went thru 3 of the Best Buy freebies, and all 3 charge my Note for 2 to 3 minutes then begin to blink blue and charging stops.
    I called Samsung today and they sent me prepaid UPS tags to return theae and are sending new ones out. We'll see if they are any better.
    Jay G63 likes this.
    08-24-2015 08:02 PM
  8. dasupaman23's Avatar
    Going to give this a shot. Thanks
    Jay G63 likes this.
    08-24-2015 08:03 PM
  9. Davenurse's Avatar
    I have free BB black one and have had no problems at all. Put it on charger last night at 20%, woke up with full charge.
    Sent from my awesome Note 5
    Jay G63 and drewood31601 like this.
    08-24-2015 08:04 PM
  10. OldTrader's Avatar
    I have the same problem with the black one I received from BB, charges for a few minutes then flashes blue. Going to return it tomorrow.
    Jay G63 likes this.
    08-24-2015 08:38 PM
  11. Jay G63's Avatar
    Best of luck on the replacement.
    08-24-2015 09:06 PM
  12. Jay G63's Avatar
    Uodate: Put phone on new charger at 9:15 last night with battery on 55%. Woke up at 2:15 light green on charger battery at 100%.
    08-25-2015 02:21 AM
  13. ggee6688's Avatar
    I put the thick packaging from my screen protector on top of the charger, it went to green. Definitely not something that should happen for such an expensive charger. If I had to pay for it of course. It works with my and my wife's LG G4 with no issues.
    Jay G63 likes this.
    08-25-2015 03:33 AM
  14. Jay G63's Avatar
    Yeah people shouldn't have to do things like this to get them to work.
    08-25-2015 03:58 AM
  15. Frenzytom's Avatar
    Same problem with the black charger. Drains battery and not charging.
    Sent from the Note 5
    Jay G63 likes this.
    08-25-2015 06:22 AM
  16. sfla99's Avatar
    Correct me if I am wrong but I am pretty certain the issue is actually the way wireless charging is handled that you are seeing drain overnight, so if you put phone down at 9:00 and it takes three hours to charge it will run its full cycle by 12:00, the wireless charge sync then shuts it's self off when light goes green, now your phone is sitting in standby mode from 12:00am till when ever you get up and take it off the platter.
    So assuming you are losing roughly 2% per hour and it sits idle not charging for 6-8 hours you would potentially pick up your phone in the morning and be at 88% battery roughly.
    I think the issue is that once the wireless cycle ends it requires the phone to be reseated to start wireless charging again, the phone will not sense it's low and try and keep it topped off.
    Theresa Humphries and Jay G63 like this.
    08-25-2015 06:56 AM
  17. Jay G63's Avatar
    I woke up with 100% charge. It didn't start draining after being full and my wife's charger is the same way.
    08-25-2015 09:19 AM
  18. Hippocampus's Avatar
    I have a black one and it has this issue real bad.
    Jay G63 and stanleybb50 like this.
    08-25-2015 09:22 AM
  19. Kamen's Avatar
    I am in the same boat. I purchased the Note 5 and my wife purchased the S6 Edge+ and both wireless chargers (black) that we received will stop charging after roughly 5 to 10 minutes.
    I thought at first it stopped charging when I received a new notification (a buddy of mine posted something to my Facebook wall and right as I got the notification it stopped charging), but then I monitored it for a little bit and found that this was not the case.
    I also have a TYLT wireless charger that I use at work and it charges flawlessly. I am going to try the Daydream settings tonight to see if that helps and if not I am going to see if Best Buy will let us swap them for TYLTs as they are basically the same price.
    Jay G63 likes this.
    08-25-2015 09:59 AM
  20. mrhankey184's Avatar
    Yes, this is a issue IMO. A $50 charger should out perform a $5 wired charger. I'm shocked this product hasn't been recalled. I'm going to try to exchange and see if I get a unit that works. Thus far, this is my biggest issue with the note 5 purchase even though it's not directly note 5 related.
    08-25-2015 11:05 AM
  21. schwartzki's Avatar
    Add me to the list having problems with the black Samsung wireless charger that I got free from Best Buy. Woken up to blinking blue light and no charge with Pelican Defender case on. Last night had a thin clear case on and woke up to green charged but only 88%.
    Jay G63 likes this.
    08-25-2015 11:08 AM
  22. rustypixel's Avatar
    There's definitely an issue. I started a thread about this a couple of days back. Since then I went to BB and replaced the puck with a new one (same charger) and it's been working as it should. I wanted to make sure it want' my N5 so I tried the first charger with my older Droid MAXX and the same thing happened.
    Jay G63 likes this.
    08-25-2015 11:25 AM
  23. bplink95's Avatar
    I've had my black samsung wireless charger almost 2 months and never had this happen with my regular s6 edge. Got the new s6 edge plus Friday and now get the blinking blue light errors and it stops charging. My girlfriend kept her regular s6 edge and it will charge with no problem on it. Smh... this is getting frustrating.
    08-25-2015 12:40 PM
  24. stanleybb50's Avatar
    Posting this on all the wireless charger threads because I was so excited at how well it worked last night!
    I got this one from Amazon yesterday and it worked flawlessly! Woke up and the red charging led on my phone was still lit, as well as the led on the charger saying it was connected. Phone was cool, and it was at 100%. I LOVE the fact that it's tilted/angled as well.
    Wireless Charger, Spigen® [Wireless Charging Pad] 3 Coil Charger [F300W] Premium Wireless / Qi Charging Stand Only for Qi Enabled Phones Galaxy Note 5/Galaxy S6 Edge Plus/S6/S6 Edge/Tablets Only - F300W (SGP11480) https://www.amazon.com/dp/B00UGIA0WY...cUvbUpU4641264
    08-27-2015 09:47 AM
  25. Imprzya's Avatar
    I have the black Samsung from Best Buy as well and I have yet to wake up to a full charge. I've used it every night, made sure it's charging, and then it usually stops and starts flashing blue, which is pretty annoying in the middle of the night. The most change I've gotten out of it is 80%. Has anyone been able to return it to Best Buy for a different kind of wireless charger?
    08-27-2015 10:22 AM
49 12
  1. Why is my Galaxy Tab 3 stuck on Samsung logo?
    Last Post: 08-24-2015, 07:01 PM
  2. Replies: 1
    Last Post: 08-24-2015, 06:57 PM
  3. Replies: 0
    Last Post: 08-24-2015, 06:26 PM
  4. Why won't my Samsung Galaxy S3 turn on?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 08-24-2015, 06:17 PM
  5. Why won't my Samsung Galaxy S3 turn on?
    Last Post: 08-24-2015, 06:16 PM
