1. ELAkid's Avatar
    My phone takes a long time to charge,I'm use the chargers that came with it ,and there's a notification that will say the percentage of the charge, and it says approximately 1 minuter until fully charged yet it seems like it takes forever.
    My Note 4 would charge to 100% in like and hour from 10% has anyone's else experienced this?
    08-25-2015 08:33 AM
  2. russel5150's Avatar
    You said chargers that came with it.. are you using a free wireless charger that has been given out with this phone? The reason I ask is the fast wireless charger has not been released yet, and many people who were getting a wireless charger thought it was the new fast charger. So if you are using a wireless charger that came with the phone it will charge at a slower rate.
    Sent with my white Note5 with nonremovable back and no SDcard!
    08-25-2015 09:20 AM
  3. ELAkid's Avatar
    No the regular cord and brick that came with it, I hooked up my Note 4 charger and it charged up but I'll have to test it later when it drains to see how fast the note 4 charger takes,it might just be the cord by the way this phone is nice
    08-25-2015 09:31 AM
  4. anon(607340)'s Avatar
    My wife had the same issue, and it was a defective wall wart (the part of the plug that goes into the wall, that the cord plugs into)
    Switched it out with another one I had from the S6 and it went back to Fast Charging
    08-25-2015 10:14 AM
  5. ELAkid's Avatar
    Yeah I'm thinking it might be the cord, the only thing that got me thinking is from my ride to work the battery dropped 8% strava running an rhapsody this is my first full day with the note 5 ,my Note 4 wouldn't drop that much I'll have to monitor the battery and charge it up with my Note 4 cable, and see how it goes thanks for posting
    08-25-2015 10:45 AM
  6. anon(607340)'s Avatar
    First two days my battery was taking hits from cell standby but it settled yesterday and now getting 16 hours easy plus 4 to 5 hours SOT running live wallpaper and a data intense launcher.
    Sent from my SM-N920T using Tapatalk
    08-25-2015 10:51 AM
  7. ELAkid's Avatar
    Cool,yeah I read somewhere on here that the battery will sometimes get better after a few cycles,I'm going to wait, and I hope it gets better ,did you guys ask for a new cable for your wife's phone?
    08-25-2015 11:03 AM
  8. anon(607340)'s Avatar
    No it was the wall wart not the cable. You know, the little square that plugs into the wall itself, that the cord or connected to. I had spares from our S6's so I just swapped that out, the cable itself was fine.
    08-25-2015 12:04 PM
  9. ELAkid's Avatar
    Oh OK, that's good it was something simple
    08-25-2015 12:09 PM
  10. bbsemiaddict's Avatar
    Why doesn't it say if plugged into the fast charger FAST CHARGING. It says it (at least when I viewed a video of it) for a FAST WIRELESS CHARGER, but why not say fast charging on the wired charger?
    08-25-2015 12:38 PM
  11. Glock23-G4's Avatar
    It does.
    Standard charger says "cable charging" and the fast charger says "fast charging."
    08-25-2015 12:42 PM
  12. bbsemiaddict's Avatar
    It didn't the first 3 or 4 charging attempts out of the box, but then it started showing the Fast Charging. I think it needs a few power cycles when new to initialize the battery, was mentioned on another thread.
    08-31-2015 10:20 AM
  13. ELAkid's Avatar
    Yeah I stopped using the charger that came with my note 5 thinking it was defective but then one day I plugged it in and voila it works good now,like you said it probably needs a few power cycles.
    09-02-2015 02:47 PM
  1. Replies: 17
    Last Post: 09-04-2015, 01:45 PM
  2. Replies: 2
    Last Post: 08-27-2015, 03:42 PM
  3. Replies: 1
    Last Post: 08-27-2015, 03:40 PM
  4. Will there be a 128GB Note 5 here in the US?
    By felloffthetruck in forum Samsung Galaxy Note 5
    Last Post: 08-25-2015, 09:31 AM
  5. Can I remove the music bar from my locked screen?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 08-25-2015, 08:00 AM
