1. DX9's Avatar
    Had the Note 4 last year forba bit. One feature I always liked was in Call Settings you have the option to have a small incoming call box instead of a call taking up the entire screen while I was doing something on my phone.
    Mark "Incoming Call Notifications", so notification pop-ups for incoming voice calls when the screen is on.
    Looks like they took it out. Android L uses it. Pretty surprised Samsung took it out. Great feature
    **Edit never mind. It works**. Only works while in an app. I was on the Home when getting a few calls.
    08-27-2015 05:51 AM
  2. anon(153966)'s Avatar
    I never knew this, and just tested it.
    From the home screen, I received a call, and the 'screen' was small, the top of the display. I then clicked on the icon in the top right, to maximize the view.
    I then called my device again, to merely test if it kept the full screen, and it doesn't. Which is okay, I was just curious...
    08-27-2015 08:36 AM
  3. DX9's Avatar
    See if I'm just in my Home Screen and not in an app the entire screen has an incoming call. If I'm within the browser or any other app it is a minimized call box at the top
    08-27-2015 09:34 AM
  4. Glock23-G4's Avatar
    This is how mine is as well, I think.
    08-27-2015 09:39 AM
  1. Replies: 5
    Last Post: 03-13-2017, 05:16 AM
  2. Replies: 1
    Last Post: 08-27-2015, 04:32 AM
  3. Inside screen on tablet cracked,can it be fixed?
    Last Post: 08-27-2015, 04:27 AM
  4. Replies: 0
    Last Post: 08-27-2015, 03:19 AM
  5. Galaxy Note 5 WiFi Calling Battery Drain
    By skerfan2284 in forum Samsung Galaxy Note 5
    Last Post: 08-27-2015, 02:27 AM
