1. JAG21979's Avatar
    When I'm in my wife's Subaru Forrester and connected to the car media via Bluetooth, I have to swipe first, then put my thumb on the fingerprint scanner to log in. Is anyone else having this issue? I should be able to simply place my thumb on the reader and unlock my note 5.
    08-28-2015 08:03 PM
  2. dasupaman23's Avatar
    Did you set it up as a trusted device?
    Sent from my Note 5
    08-29-2015 12:29 AM
  3. JAG21979's Avatar
    Sent from my Note 5
    I don't believe so, I'm not sure how to do that.
    08-29-2015 09:23 AM
  4. mhunter6378's Avatar
    Go to Settings>Lock screen and security>Secure lock settings>Smart lock and while in range of / connected to your vehicle's Bluetooth select Trusted devices and add it. This way whenever your connected to that Bluetooth your lock screen security will be bypassed. I use this with my Gear 2, works great. The lock screen security will resume when you're out of range of the Bluetooth or the Bluetooth is disconnected for any other reason.
    08-29-2015 01:44 PM
  5. MDMcAtee's Avatar
    Didn't have any issues hooking up on my new Chevrolet Silverado
    Posted from my Galaxy Note 5
    08-29-2015 02:10 PM
  1. Why can't I use 4G while connected to my car using bluetooth?
    Last Post: 09-19-2015, 08:48 PM
  2. What is wrong with my phone?????????
    Last Post: 08-30-2015, 12:10 AM
  3. Replaced charging cable with a six ft one...
    By larrykay in forum ASUS ZenPad S 8.0
    Last Post: 08-28-2015, 07:07 PM
  4. Can I get some help with keeping my phone on?
    Last Post: 08-28-2015, 07:01 PM
  5. Replies: 0
    Last Post: 08-28-2015, 06:12 PM
