having issues connecting to wifi 5g
smalba
501
5
18
So I'm able to connect to normal wifi 2.4g but when I switch to my 5 g wifi it either disconnects me after a certain amount of time or it just switches back to normal wifi . How can I keep my phone on 5g wifi?
smalba
501
5
18
I might have found a fix. I have an Asus router and I switched my channel from auto to a low setting chanel and it seems to be working now.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
It's choosing the better signal. If you can turn off 2.4GHz on your router, do so. Otherwise, you want the better signal.
smalba
501
5
18
That's the thing my 5g signal is way better and stronger. But it seems to be working now after choosing the channel.
smalba
501
5
18
Never mind the issue is still here this morning. I'm starting to think that the note 5 for some reason has issues keeping a connection with a 5g wifi signal. I have a pc and another tablet that are working fine with my wifi 5g connection.
mhunter6378
1,482
No, I have a dual band router running simultaneous 2.4 and 5, I have mine set to pick the 5 first and it always does and stays connected to it.
smalba
501
5
18
Okay guys I really need some help here. I can't keep my 5g wifi connection connected on my note 5. All my other devices stay connected but my note 5 will just not connect or get disconnected after a fee minutes. What can I do? I have forgotten my normal wifi connection so that my 5g will let be the priority but that didn't help.
Misterb
742
I have no problems. The way my 5g network has always been, is that it is a separate network from my 2.4. I log newer devices on to the 5g, and older devices, or those that aren't compatible with the 2.4. I don't let the router choose. I choose. The Note has been on the 5g network Since day one, and it works really well
nokia4life
853
10
Same here mine is set to choose the 5ghz signal first. No problems holding on if anything it always stays on it and never jumps to the other bands
Sent from my SM-N920I using Tapatalk
Gray Area
1,518
No issue staying on 5g on mine and I have 2, 2.4ghz channels and 2, 5ghz channels. I don't even put in the key to login to my 2.4ghz channels, that may help you as well because then your note 5 won't have another ch to switch to. I'm using a netgear nighthawk router connected to a generic Comcast Cable modem/router combo. All is well.
Posted from my Beast Galaxy Note 5
DEVICE HISTORY (since they got smart)
PHONES: Galaxy Nexus, LG viper, Galaxy s3, HTC Evo 4g, Galaxy Note 2, Galaxy s5, LG G-Flex, Galaxy Mega 6.3, Galaxy s6 edge, Galaxy Note 5. TABLETS: Galaxy Note 10.1 gt-n8013, Galaxy tab 3 7.0. WATCH: Galaxy gear
