1. Ironzey's Avatar
    Is there a way to turn off the alert that notifies you when wireless charging is engaged?
    This phone sits on my nightstand and chimes and turns on the screen every time the wireless charging kicks in. This disturbs me and my wife while we're sleeping.
    This is my second phone with wireless charging and to be honest it's pretty finicky/annoying. With the Nexus 6 I had to place the phone perfectly or it wouldn't charge and the phone would get pretty warm while on the charger. The Note 5 is pretty finiky on placement also. The screen on/notification sound are both pretty annoying to deal with.
    What ever happended to docks?
    08-31-2015 09:24 AM
  2. ccpopham's Avatar
    The finicky placement is more with the qi charger than the phone. The charger in the phone is rather limited due to spice limitations on the phone. The qi chargers with 3 coils allow more placement options than the single coil models.
    I am not as sure about the sound or the turning on of the light. I take my screen off of auto and dim it to the lowest setting. Now you may be able to turn the notification sounds off and see if that does it.
    08-31-2015 09:51 AM
  3. General Tso's Avatar
    Try the Spigen wireless charger. It designed like a dock. It works great.
    08-31-2015 10:38 AM
  4. General Tso's Avatar
    Here's the Spigen wireless charger.
    08-31-2015 10:42 AM
  5. Ironzey's Avatar
    I bought one with 3 coils from Amazon. It was pretty highly rated I can only imagine how much of a PITA a single coil unit would be.
    I haven't tried turning down the sound. I did set up do not disturb with exceptions.
    Sounds like I'll have to wait for the ROM makers.
    08-31-2015 12:22 PM
  6. ccpopham's Avatar
    I use a paid app from the play store called Tasker. I have a task that I run when I go.to bed. The task turns down my volume and adjusts my display brightness. I believe you can use exceptions for it as well.
    08-31-2015 12:27 PM
  1. Sometimes the fast wireless charger isn't work properly
    By duncan0622 in forum Samsung Galaxy S6 edge+
    Last Post: 09-01-2015, 08:45 AM
  2. How long do I charge my Samsung A5 for the first time?
    By AC Question in forum Samsung Galaxy A5
    Last Post: 08-31-2015, 11:35 AM
  3. Why is my volume turning off on S4 when headphones plugged in?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 08-31-2015, 10:19 AM
  4. How can I get sound on videos?
    Last Post: 08-31-2015, 10:15 AM
  5. iron man shooting notification sound
    By jus71n in forum General Help and How To
    Last Post: 08-31-2015, 08:40 AM
