Using Wi-Fi causes Cell Standby bug (Verizon)
stanleybb50
185
Can you do a screenshot of the battery and the usage under it and also make sure your notification bar is in the screenshot.
I'm actually good today because I'm out at work, but amazingly, it's still #1...! I might have been on wifi for an hour or so this morning?
Here's today:
Here's the other day when I was at home:
Sent from my SM-N920V using Tapatalk
Kelly Kearns
8,729
6
Here's today:
//images.tapatalk-cdn.com/15/09/10/4bf2d9e38b6a081e3f5b50c13641ea21.jpg//images.tapatalk-cdn.com/15/09/10/b5b957bc821ffc390f80229b166a3f0d.jpg
//images.tapatalk-cdn.com/15/09/10/0f09f723bc21a297c17e7580f54eccd6.jpg//images.tapatalk-cdn.com/15/09/10/8f0702fc279eb3ade5fefdfb5dc2f9fa.jpg
OK, hold on.. I needed that picture with WiFi on also.
Kelly Kearns
8,729
6
Alright, I just don't know what is causing that and there are several on Verizon that aren't having that issue. Being on WiFi calling will cause that, it doesn't drain, but makes it a high number, but Verizon doesn't have WiFi calling.
You could try operating in safe mode for a while and see if it pops up high. If it doesn't, then an app is causing it most likely, if it does, then it is something else.
vm81
213
Most people I have read around here are having that issue with wifi on Verizon. Its not an app or any setting causing it as I have factory reset 2 phones today and put on wifi...they are both draining 5-7% every hour on standby with absolutely nothing installed or logged in. Its definitely NOT an app.
I am not able to get a screenshot up...but I am sure it is the fact that 4G is on along with Wifi that is causing this.
Kelly Kearns
8,729
6
That is not necessarily true, because a lot on Verizon are not having it.
Yes, the 4G is on with it, and some apps can cause that, the main one, caller ID apps.
vm81
213
Ok if an app is causing it...then why is it on after factory reset with no apps installed. If its one of verizon apps....I even disabled those and its still there.
I guess there is no resolution to this (atleast for me) until Verizon fixes it.
Kelly Kearns
8,729
6
I didn't say an app IS causing it, I said, just like earlier, an app can be causing it, which is the reason for the testing.
All Verizon people aren't having it, so not sure how much is a "Verizon" issue.
There are a couple from AT&T having it also.
Dhawk1202
345
This may have been covered, but I'm personally on Tmobile. When I first got my N5, Cell standby was always on top of my battery drain, no matter how long I had the screen on. I'm someone who had always had the wifi setting set to "always stay on" while my screen is off. I changed that setting to only connect to wifi when my screen is on, and poof, it fixed the problem immediately. Cell standby is always near the bottom. Now I'm getting great battery life, and all is well. Again I'm sorry if this does not pertain to this thread, or if it was covered already. I just wanted to share my success.
vm81
213
Well in that case it might be "Samsung issue" and the way it is working with Verizon radios....but its an issue with Verizon or Samsung and needs to be fixed.
vm81
213
Dont have option to do it when screen on. Only options are:
1) Always
2) When connected
3) Never
vm81
213
I'm sorry again... Keep wifi on during sleep (Never) is what I have set. Lol
But thats not a solution as it is going to use data while it is not sleeping...sometimes can be a lot. And also...it will use battery to connect to wifi every time you wake the phone up. And finally battery drain will happen due to cell standby will happen while the phone is awake. I am sure it is better this way than having it always on...but this is not a solution to the problem.
Dhawk1202
345
I understand, though I've noticed a huge improvement in battery, and no added data used. I have regular app syncs too. Just my experience.
Dhawk1202
345
You're right though, I believe with wifi on LTE is still running too. (Seems like a bug to me) but if you have wifi Off while screen is off then it's just using LTE while screen is off (of course using data for syncing) That's how I understand it, and since it's Verizon and Tmobile, it might be a Samsung N5 issue.
spasell
584
The issue is in fact related to WiFi and LTE being on together. When I turn my WiFi off my battery improves by almost 25%!!! That's ridiculous.
Another issue. When I select to have WiFi sleep when the screen so off IT DOESN'T WORK. I use GSM battery and shows WiFi and cell at the time connected despite having checked that option. Very aggravating
