1. mlprce's Avatar
    So I was one of the unlucky ones to get a charger that would not charge my phone. I have gotten the run around by both best buy and samsung. I have my charger on the table beside my couch. I usually throw the phone on there while sitting on the couch, picking it up and placing it back down. Apparently I found a sweet spot today. Leaving the phone on there the way it was sitting I was able to do from 45%-100% and keep it there for a few hours I also ran videos to try and run the battery down but want able to. So here is how I had it sitting. Hopefully you can see from the pics the angle of the phone. I took the first one straight up. Maybe it will work for others maybe not.
    Attached Thumbnails Fix for best buy samsung wireless charger...maybe-1980.jpg   Fix for best buy samsung wireless charger...maybe-1979.jpg
    08-31-2015 08:10 PM
  2. ajbrad71's Avatar
    Just put in daydream mode and wala you good
    08-31-2015 08:40 PM
  3. mlprce's Avatar
    Daydream didn't work for me.
    08-31-2015 08:49 PM
  4. cvflowe's Avatar
    I put my phone in do not disturb and it seems to work most of the time.
    08-31-2015 09:01 PM
  5. papaofdaneel's Avatar
    This might sound stupid but make sure when you put your phone down on the charger that Samsung branding on the charger and your phone is laying the same. So pretty much if you lay your phone on the charger the top of the phone should be facing the chargers cable.
    08-31-2015 10:14 PM
  1. Replies: 1
    Last Post: 08-31-2015, 10:37 PM
  2. How do I magnify on my Samsung Note 5?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 08-31-2015, 10:33 PM
  3. what driver do i need from computer to fix my coolpad
  4. Samsung Gal. 4 will no longer locate towers, why?
    Last Post: 08-31-2015, 10:28 PM
  5. How can I root my Samsung Galaxy Avant?
    Last Post: 08-31-2015, 05:53 PM
