1. Hend Mora's Avatar
    Hi, Would you know how can i connect my new note 5 to my samsung gear s?
    08-31-2015 11:36 PM
  2. TJohnsonmp01's Avatar
    Turn Bluetooth on ur phone...install Samsung Gear app...press sync...it'll give u a code on each device u press ok n ur good to go
    08-31-2015 11:40 PM
  3. DeepSeaGoddess's Avatar
    If you had the gear s connected to a different phone before the note 5, you'll likely have to 'factory reset' it before connecting to the note 5. I had to do that and another person did as well when I posted in the forum.
    09-01-2015 06:52 AM
  4. Jamez Avila's Avatar
    Yes, I'm using my Gear S just fine with my Note 5.
    Posted from my Galaxy Note 5
    09-01-2015 12:34 PM
  5. Jamez Avila's Avatar
    And yes, it will force you to reset the Gear S before it will pair with the Note.
    09-01-2015 12:35 PM
  1. (galaxy note 5) wifi youtube
    By Hector Bernal1 in forum Ask a Question
    Last Post: 09-06-2015, 12:01 AM
  2. My first Note: Stylus Skipping Question
    By orangeman in forum Samsung Galaxy Note 5
    Last Post: 09-01-2015, 08:53 AM
  3. Replies: 1
    Last Post: 09-01-2015, 01:58 AM
  4. Replies: 1
    Last Post: 09-01-2015, 01:56 AM
  5. How to connect Note 5 to samsung gear s?
    Last Post: 08-31-2015, 11:24 PM
