1. AC Question's Avatar
    The plastic click top of the new stylus broke off. I had to use a set of needle nose to get the stylus itself out.
    And no...I did not put it in backwards. Anyone else have this problem?
    I can't find a place to purchase a new one? Hoping that they'll replace it? It hasn't even been a week!
    09-01-2015 12:19 PM
  2. Sooks's Avatar
    I have had two Note 5s (One black 64, one White 32) my black one felt loose from day one and ended up doing this same thing. My white one felt really sturdy and doesn't even wiggle... I think there were a bad batch of pens.. I contacted samsung and asked for a new pen and was told to just swap out the entire device with the carrier.
    09-01-2015 12:35 PM
  3. nyc_rock's Avatar
    If it's only been a week, take it back.
    Kelly Kearns likes this.
    09-01-2015 12:36 PM
  4. Alecinator's Avatar
    Yeah, my click-top seems to be jammed so I can't click it to remove my stylus from my phone. Guess I have to go buy a pair of pliers.
    09-01-2015 02:29 PM
  5. Kelly Kearns's Avatar
    If your spen top is broken, you need to take the phone back and get a new phone.
    09-01-2015 03:20 PM
  6. k3m1c6's Avatar
    This is my biggest fear for me even more so then dropping my naked N5! You see, I'm a clicker! When I have a ball point pen in my hand I am constantly clicking the top! I do it without thinking and my fear is I will break, wear out and basically destroy my spen!
    I'm sure soon they will be avaliable everywhere but....... yeah!
    Posted for my Galaxy Note 5 with a properly inserted S Pen!
    09-01-2015 03:36 PM
  7. Glock23-G4's Avatar
    I generally just leave mine un-clicked. The Pelican case is thick enough that the pen still doesn't protrude, so it's one less step for me to remove the pen, and less wear and tear on a moving part.
    09-01-2015 03:41 PM
  8. Diraan's Avatar
    I saw a few on eBay for around ~$14.
    They claim to be original, but who knows. Here's a link to one:
    New Original Touch Stylus s Pen for Samsung Galaxy Note 5 N920F N920I N9200 | eBay
    09-01-2015 05:28 PM
  9. rgh718's Avatar
    If it comes out fine but if its stuck inside then you should take it back
    09-01-2015 09:17 PM
  10. husslord's Avatar
    Yep happened to me today! Was trying out two tech 21 cases. The top broke off and took some time but I took a paperclip and was able to insert it in the part that was now open from the top breaking off. I called att, they are overnighting me a new one... I am started to think of really going with a slim class like the Samsung clear back protector now...not happy after three weeks this happened already!
    09-02-2015 05:20 PM
  11. barry99705's Avatar
    That's what I'm doing as well. The clicker quit working, used a piece of tape to pull the stylus out, then wrapped some string around the top after it popped out so it can't click back in.
    I'm not replacing the whole phone just because the clicker quit working. I'd have to set everything back up!
    Note 5 - stylus click-top broke off! Can I replace it?-img_20150902_190552.jpg
    09-02-2015 06:03 PM
  12. Kelly Kearns's Avatar
    What you can do is wait a short time and return the spen to Samsung. On fact I would call then and tell them that is what I want to do. Generally they try first to repair spens, not just replace them.
    09-02-2015 07:09 PM
  1. Verizon phone call clicking noise
    By SnoFire in forum Samsung Galaxy S5
    Last Post: 09-29-2015, 07:57 PM
  2. Replies: 2
    Last Post: 09-01-2015, 12:14 PM
  3. Why won't my Note 4 allow music downloads?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 09-01-2015, 11:38 AM
  4. Replies: 0
    Last Post: 09-01-2015, 11:28 AM
