1. eperjesikev's Avatar
    I'm thinking about getting the note 5 phone and gear 2 watch. I was wondering if the gear 2 watch will work on the note 5 and if not what other watches will.
    09-01-2015 10:34 PM
  2. russel5150's Avatar
    They should, they are both samsung.
    Sent with my white Note5 with nonremovable back and no SDcard!
    09-01-2015 11:14 PM
  3. sux2bu's Avatar
    Yes, mine works fine.
    09-02-2015 12:52 AM
  4. mhunter6378's Avatar
    Works great with mine too.
    09-02-2015 03:39 AM
  5. JohnnytheK's Avatar
    Mine connects automagically, and texts, emails, phone calls all get routed through the gear 2. Except the weather, it randomly syncs maybe twice a day. I've tired every weather widget and that one thing stymied me!
    Sent from my SM-N920T using Tapatalk
    09-13-2015 12:19 AM
  6. jdhooghe's Avatar
    Yes
    from my smexy Note 5
    09-13-2015 12:45 AM
  7. JohnnytheK's Avatar
    Woo hoo! I fixed my problem, I had the right widget, but Nova launcher was the problem. The weather is on my lockscreen and syncs with my Gear 2 perfectly! Getting used to the stock launcher, not bad I think after a bit I'll like it.
    09-15-2015 11:42 AM
  8. dpham00's Avatar
    I think that you can use Nova and just add the stock weather widget, set it to update hourly
    Sent from my Verizon Samsung Galaxy Note 5
    09-15-2015 12:22 PM
  9. JohnnytheK's Avatar
    Tried didn't update, which is too bad cuz I've used nova on my last few phones. Might be a T-mobile thing.
    09-15-2015 12:24 PM
  1. Replies: 4
    Last Post: 02-03-2016, 07:08 PM
  2. How do i turn off voice commands on my LG G3?
    By AC Question in forum LG G3
    Last Post: 09-02-2015, 04:48 PM
  3. How big is the S6 Edge+?
    Last Post: 09-02-2015, 01:35 AM
  4. Replies: 1
    Last Post: 09-02-2015, 01:33 AM
