1. xAVx's Avatar
    Hi,
    I was wondering if any of you guys experience issues with the phone being too hot? Mine constantly goes to about 35 - 37 degrees from a few activities, namely when I play Hearthstone, or when i charge it via wireless...Is it a faulty unit?
    Thanks!
    09-02-2015 03:31 AM
  2. Kelly Kearns's Avatar
    Hi,
    Thanks!
    That temperature is within normal ranges.
    09-02-2015 11:46 AM
  3. kroman1975's Avatar
    My note runs perfectly cool. No problems at all.
    BergerKing likes this.
    09-02-2015 12:12 PM
  4. Dhawk1202's Avatar
    This phone has been the coolest running phone I've ever had. Even after watching a bunch of YouTube it never gets above 95 degrees.
    09-02-2015 12:33 PM
  5. sheba510's Avatar
    So far I have not noticed any heating issues with my Note 5 and battery standby has been awesome. I did have heating issues and battery drain with the S6 edge which is why I dumped it and got the Note 5. If you are feeling excessive heat and/or battery drain with your Note 5 you might want to try to exchange it. The problem will only get worse with time. You could also try a factory reset to see if that clears up any problems you may be experiencing.
    09-02-2015 04:48 PM
  6. dpham00's Avatar
    It seems around normal. My g4 got up to 125 deg F and automatically dimmed the screen when using navigation... Now that was overheating....
    Sent from my Verizon Samsung Galaxy Note 5
    09-02-2015 06:31 PM
  7. xAVx's Avatar
    kroman: Is that with playing games even? Cuz i read from some other users on XDA that their phone stays pretty cool even while playing VainGlory and stuff, but mine heats till about 37-38 and it is rather warm to touch being in a tropical country!
    09-03-2015 12:29 AM
  8. Willyman's Avatar
    Mine definitely gets slightly warm to the touch... but then I'm in Hong Kong with 32-35 degrees weather at the moment. I was concerned as well in the beginning, but I tried doing exactly the same things on my OnePlus One (ie. high res youtube video) and they were about the same temperature.
    09-03-2015 03:56 AM
  9. Steve WIn's Avatar
    After uninstalling Baidu Browser (which installed itself), my Note 5 is no more overheated and battery life back to normal. Looks Baidu Browser is a bad application that install itself without my knowledge.
    02-03-2016 12:14 AM
  10. srinathp1988's Avatar
    I have had heating issues right from day 1. I even got my phone replaced after 1 week. I felt the phone was hot compared to my note 3..even now usually the temperature is around mid 80s ans it gets upto mid 90s when i play games or watch you tube. But now it's less annoying - I guess i got used to the heat..
    02-03-2016 12:20 AM
  11. Climb14er's Avatar
    Very cool running phone. In fact, compared to my earlier Samsung and Motorola phones, this Note 5 barely breaks a sweat.
    02-03-2016 09:58 AM
  12. armallard's Avatar
    I'm charging mine as reading the forum and mine is @ 91 degrees
    02-04-2016 01:10 AM
  13. Vinaychandel1230011's Avatar
    02-04-2016 02:49 AM
  14. BergerKing's Avatar
    I push the heck out of my GN5 and it's yet to break a sweat.
    02-04-2016 05:48 AM
  15. garak0410's Avatar
    I took a video over 10 minutes the other day and it shut down the camera off and said to try again when the phone was cooler.
    04-12-2016 10:56 AM
  16. cwbcpa's Avatar
    Consistently the coolest running phone I've had in a while. It gets a little warm if a play an action game but not bad at all. At least as cool as my 6s Plus.
    04-12-2016 11:06 AM
  17. gozirra's Avatar
    Mine only overheats when plugged into my Gear VR. You may have one or more apps going wonky, or poor reception.
    04-12-2016 11:26 AM
  18. Alchemistaj Adrian's Avatar
    MIne overheats severely in my gear vr and it takes all the fun out of it as soon as I find what I want to do I find out that its too hot and will run better cooled down it gets kinda hot in my cases as well stunning phone gotta get used to it for 2 yrs I guess ha not a deal breaker because of all of the other great features of the phone.
    04-19-2016 06:03 AM
  19. gozirra's Avatar
    Get you some of these, it solved my overheat issues with the Gear VR.
    http://www.amazon.com/Reusable-Packs...cUvbUpU5134590
    04-19-2016 11:06 AM
  20. garak0410's Avatar
    One thing I didn't so...after the update to Android 6.01, I didn't do a factory reset. I didn't feel like I had to because it has been running so well. But videoing has been wonky and with the overheating, wondering it it could help to do a factory reset.
    04-19-2016 02:44 PM
  21. gozirra's Avatar
    It's a good reason to clean house and get rid of stuff that may be causing conflicts too. If anything isn't working 100% and Google hasn't acknowledged it as a bug, a factory reset will probably fix it.
    04-20-2016 11:04 AM
  22. Trees's Avatar
    That's a good point about cases. If they don't "breath" well, then may be something to keep in mind as summer approaches. My region can easily see 40+C in the shade for weeks on end (I sure hope that won't be the case this year) Since many of us likely got the Note 5 in the cooler months (if in the Northern Hemisphere), will be interesting to see how the Note 5 handles the summer heat.
    04-21-2016 07:23 AM
  1. Will the Note 5 work on the gear 2?
    By eperjesikev in forum Samsung Galaxy Note 5
    Last Post: 09-15-2015, 01:24 PM
  2. How can I get my Note 3 to connect to my PC?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 09-04-2015, 10:27 PM
  3. How can I get into my Note 4?
    By wingtrl in forum Samsung Galaxy Note 4
    Last Post: 09-03-2015, 08:33 AM
  4. Replies: 16
    Last Post: 09-02-2015, 11:23 PM
