1. Marcx662's Avatar
    Everything is enabled in settings but when I pull the S Pen out Air Command doesn't open, only a notification at the top saying the pen was removed.
    Am I missing something here?
    09-03-2015 12:57 PM
  2. giftedmd's Avatar
    You mean this setting is turned on and still doesn't work?
    Sent from my SM-N920T using Tapatalk
    09-03-2015 01:54 PM
  3. Marcx662's Avatar
    Yes, that is enabled and still nothing...
    09-03-2015 02:59 PM
  4. metaden's Avatar
    I have the same problem. Did you work out any solution?
    01-29-2016 11:34 AM
  1. Replies: 1
    Last Post: 09-03-2015, 12:59 PM
  2. Replies: 0
    Last Post: 09-03-2015, 12:55 PM
  3. Why isn't my computer recognizing my S6 from this morning?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 09-03-2015, 12:37 PM
  4. Replies: 1
    Last Post: 09-03-2015, 12:18 PM
  5. How do you get S6's filter "magic pen" on the Note 5?
    Last Post: 09-03-2015, 10:43 AM
