1. KSY77's Avatar
    Hi, I bought the new Samsung Note 5 Clear View Case with the Note 5 on Aug 21, 2015 and have been testing it out for a couple of days now. Despite the case making the phone look slightly bigger and heavier, I really like being able to answer calls and controlling various functions through the flip cover and not having to flip the cover over to access the phone. Really cool feature. And the S-Pen also works with the cover. I was also afraid that the new case would not work with the Samsung wireless charger but found out that the phone will charge with the cover on as well. Check out the youtube demo here:
    I'm usually not a big fan of covers but I really do like this clear case. The only downfall I find is that the case itself is not as scratch resistant as I would have liked it to be. I already have a 3x3 mm scratch on the front cover as a result of my keys. But generally, I'm quite happy with this new clear case.
    What about other wireless chargers and cases?
    SpookDroid likes this.
    09-04-2015 03:42 PM
  2. SpookDroid's Avatar
    Nice! Thanks for the tip! Most 'respectable' chargers will work with cases, unless you're using a Hulk case with TPU, plastic bumpers, acrylic protector, and a clip holster on top of it all.
    KSY77 likes this.
    09-04-2015 03:55 PM
  3. jdhooghe's Avatar
    Electromagnetic waves will not be disturbed unless the material is conducting
    Sent from my SM-N920T using Tapatalk
    KSY77 likes this.
    09-04-2015 04:59 PM
  4. SpookDroid's Avatar
    The material might not break them, but the distance added by the bulk of it all might. And does. Plenty of chargers out there that won't work unless the phone is case-less or has a very VERY thin TPU case
    09-08-2015 11:42 AM
  5. KSY77's Avatar
    Here is the clear view back cover...not the flip cover one
    10-15-2015 08:31 PM
  6. Cwey55's Avatar
    We should start a list of cases that don't stop wireless charging much like we make lists of bloat apps to disable and such...
    10-15-2015 09:43 PM
  1. Locked out of my Galaxy Note 4...HELP!! How can I get back in?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 05-09-2016, 02:51 PM
  2. Replies: 0
    Last Post: 09-04-2015, 03:16 PM
  3. Replies: 0
    Last Post: 09-04-2015, 02:50 PM
  4. Replies: 0
    Last Post: 09-04-2015, 02:49 PM
  5. Replies: 0
    Last Post: 09-04-2015, 02:45 PM
