1. Vic Sol's Avatar
    If you're one of us, that gets those annoying sounds from your Samsung android, you'll like this.
    Go to your settings, then to accessibility and then to reminders...you can shut tem off or pick a few to be reminded, and just extend the time. you can only extended to 15 minutes though.
    Hope the helps
    SpookDroid likes this.
    09-08-2015 02:41 PM
  2. SpookDroid's Avatar
    I wonder if that option was set to active by default, and if so, which carrier did so. Those options have been there since the Note 4 IIRC, but never had I seen them active by default.
    09-08-2015 03:39 PM
  3. double923's Avatar
    I don't think it was on by default. At least my wasn't.
    Sent from my SM-T810 using Tapatalk
    09-08-2015 05:15 PM
  1. How do I fix 501 error on google play ?
    Last Post: 07-30-2016, 12:49 PM
  2. Sound profiles
    By Inspgadget113 in forum LG G4
    Last Post: 09-09-2015, 08:40 AM
  3. Note 4 Return 'vibration' and 'buzzing sound'
    By aygo1989 in forum Samsung Galaxy Note 4
    Last Post: 09-08-2015, 09:29 PM
  4. Unfortunately, launcher 4 has stopped. How do I fix it?
    Last Post: 09-08-2015, 08:48 AM
  5. my android phone could not do normal boot how to fix it?
    Last Post: 09-08-2015, 07:38 AM
