1. woojurhee's Avatar
    my note 5 sometimes gets hot at the upper back of phone. why is it doing that? Should i get another note 5? will it affect the performance in the long run? is this common for other owners with the note 5? and this happens frequently while watching videos, and while looking at facebook and such.
    09-08-2015 07:18 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! How hot does it get? It the CPU is working fairly hard, things can get pretty warm. This can happen with processor-intensive apps (like complex games) or activities (like installing a whole bunch of apps), poor cell signal (as the phone is expending more energy to try to boost the signal), and misbehaving apps.
    09-08-2015 07:26 PM
  3. coinmanmat's Avatar
    That's how hot it gets and this is from apps that are not even resource heavy.
    Peter Searle likes this.
    09-10-2015 03:14 AM
  4. nokia4life's Avatar
    mine stays about 72 with the hottest at 87 Fahrenheit
    Sent from my SM-N920I using Tapatalk
    09-10-2015 04:32 AM
  5. B. Diddy's Avatar
    The battery temp look reasonable, but the CPU temp is a bit crazy. Bring it back to the store and see if they'll give you a replacement.
    09-10-2015 10:01 AM
  6. dpham00's Avatar
    Cpu z has a known bug in the Celsius to Fahrenheit conversion.
    Note 5 Heat?-uploadfromtaptalk1441916184317.jpgNote 5 Heat?-uploadfromtaptalk1441916189477.jpg
    Sent from my Verizon Samsung Galaxy Note 5
    B. Diddy likes this.
    09-10-2015 03:16 PM
  7. B. Diddy's Avatar
    Wow--that seems like a pretty basic function to mess up.
    09-10-2015 07:02 PM
  8. dpham00's Avatar
    Yeah it has been that way for some time.
    09-11-2015 10:13 AM
  9. petereffendy's Avatar
    Note 5 is not as hot as note 4. My previous exynos note 3 is the hottest.
    09-12-2015 08:43 AM
  1. can I cut VZW MicroSIM card down and use it in the VZW Note 5?
    By centerwaters in forum Samsung Galaxy Note 5
    Last Post: 04-25-2017, 04:01 AM
  2. verizon note 5 loses time?
    By sx4dude2013 in forum Samsung Galaxy Note 5
    Last Post: 09-09-2015, 03:03 PM
  3. Can I get some help with Hotmail on my Galaxy Note?
    By AC Question in forum Samsung Galaxy Note
    Last Post: 09-08-2015, 07:52 PM
  4. Does Samsung make its own fast charging car charger for the Note 5?
    Last Post: 09-08-2015, 05:40 PM
