1. slobkabob's Avatar
    I can't seem to Swype on the Samsung keyboard but it works fine on the Swype keyboard. I can't remember if I was able to Swype on the Samsung keyboard on my old S4, but I thought I could...
    09-11-2015 11:51 AM
  2. SpookDroid's Avatar
    You can, but you need to activate it. Go to your Keyboard settings, scroll down to Keyboard Swipe and select SwiftKey Flow
    09-11-2015 12:16 PM
  3. slobkabob's Avatar
    Ok, that option [Swiftkey Flow] is grayed out and can't be selected in Settings.
    09-11-2015 12:26 PM
  4. beh's Avatar
    If it is grayed out it may be a carrier thing. I am on Verizon and I have the option for Swiftkey Flow and it works on my Samsung keyboard.
    09-11-2015 01:11 PM
  5. Jay G63's Avatar
    Sprint here, I can use it too but it isn't as fluent in recognizing like my note 2 was.
    Sent from my SM-N920P using Tapatalk
    09-11-2015 01:18 PM
  6. SpookDroid's Avatar
    Are you on any specific carrier?
    09-11-2015 01:51 PM
  7. slobkabob's Avatar
    Yes, with ATT. I'm not sue why this would be carrier dependent. Weird.
    09-11-2015 02:17 PM
  8. Glock23-G4's Avatar
    I'm on AT&T also... have the option of setting the default keyboard to either the Samsung or Swype keyboard; nothing is greyed out on mine.
    Marion Logan likes this.
    09-11-2015 03:17 PM
  9. slobkabob's Avatar
    I too can select Samsung keyboard. It's when I try to select swype under Samsung keyboard, I cannot activate it. "Swiftkey Flow", specifically is greyed out for me.
    09-11-2015 05:31 PM
  10. Glock23-G4's Avatar
    Not greyed out on mine...
    Try resetting the default keyboard settings maybe?
    09-11-2015 05:48 PM
  11. slobkabob's Avatar
    Awesome. This worked! Now I can select the Swift Key flow option (it's not greyed out). Thanks!
    Glock23-G4 and SpookDroid like this.
    09-14-2015 04:34 PM
  12. emad1995's Avatar
    It probably wasn't working because
    when the keyboard prompted you to to save your word history back when you first set up the phone you clicked no.
    09-14-2015 06:10 PM
  13. Bultaco's Avatar
    https://images.tapatalk-cdn.com/15/09...c5147f66ca.jpg
    Hey, Glock.......would you mind telling me how to create and post these great screenshots?
    Thanks,
    Mike
    04-12-2016 02:53 PM
  14. Marion Logan's Avatar
    https://images.tapatalk-cdn.com/15/09...585da84f64.jpg
    https://images.tapatalk-cdn.com/15/09...3e8f5b004e.jpg
    THANK YOU SO VERY MUCH. I received an update and the swipe option went away. It was driving me bonkers.
    07-29-2016 09:44 AM
  15. Carrie Greicar's Avatar
    I have AT&T and can swype on my Samsung keyboard.
    08-05-2016 09:20 AM
  1. Let's see it on your wrist!!!
    By fredd17 in forum LG G Watch R
    Last Post: 12-09-2015, 12:07 PM
  2. Replies: 1
    Last Post: 09-11-2015, 05:31 PM
  3. How can I Multipicture live working on my S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 09-11-2015, 11:26 AM
