1. spasell's Avatar
    The best way to charge your phone - Business Insider
    Note sure how accurate this is but if true I suspect many of us have been told the wrong info.
    jimd1050 likes this.
    09-12-2015 01:53 PM
  2. Jay G63's Avatar
    Interesting indeed.
    09-12-2015 02:02 PM
  3. sup3r1or's Avatar
    Tired of these kind of expert articles already. Just use your phone the way you want and thats it. Eventually battery will need to be changed. No amount of tips or tweaking will make 1 day battery life extend to 2 days.
    geekaren, debdroid1a and plumcrazy like this.
    09-12-2015 02:04 PM
  4. MDMcAtee's Avatar
    I don't think that the article is about getting 2 days usage but on extending the overall life of the battery.
    Posted from my AT&T 64 gig black Galaxy Note 5
    jimd1050 and Dhawk1202 like this.
    09-12-2015 04:33 PM
  5. svtalex's Avatar
    And we have none removable battery's. We can't take it out ounce its fully charged
    09-12-2015 05:10 PM
  6. armagidon's Avatar
    Anyone know how to fix a battery that jumps from 20% to 0% really quickly.... Tried deleting batterystats didn't help.
    09-12-2015 05:25 PM
  7. beh's Avatar
    All of the information in the posted article above has been well documented and reported for at least the last 5 years. That people don't pay attention doesn't make the information shocking, though it does make something else shocking.
    09-12-2015 05:54 PM
  8. smooth4lyfe's Avatar
    Doesn't the phone stop charging itself once it reaches 100% My phone once it reaches 100% it beeps as if it stops charging, and if I leave it on, it will beep again as if started charging, which I thought was because the battery went down to 99% and it started charging again
    Ry likes this.
    09-12-2015 05:57 PM
  9. pdqgp's Avatar
    Good reminder for all and a good read. All Very true.
    Slower charging is better as it creates lower heat levels but I'm sure some of the newer batteries that are meant to be fast-charged have technology that accounts for it. Heat is what kills batteries, not cold.
    I used to work for Panasonic and batteries are what they do very well. Our Toughbooks had/have an Eco Mode that charges them to 80% and holds there. The reason is that the last 20% creates the most heat. The last 20% can be charged in less than 30 minutes. Using this makes a HUGE Difference. I have a 2007 laptop that still lasts 8hrs on the original battery because of this. Most laptop batteries don't last that long.
    Even Maha batteries for my rechargeable system including tons of photography gear, suggest using low and slow charging. Not only is it better for the battery life but you'll get a deeper longer lasting charge.
    Ironically as I post this my phone is at 81% and going strong. One thing I love about the Note 5 is the wireless charging so I can now effortlessly and easily just set it down for short burst of charging while at my desk at home or the office. I tend to charge it overnight to 100% but then during the day I like to keep it in the 50-80% range. This way if I head out for a long night, I can bump it to 75-100% range easily as I shower/get ready.
    09-12-2015 06:31 PM
  1. Android Pay on AT&T Note 3.... Didnt work for me
    By Dogbert62 in forum AT&T Samsung Galaxy Note 3
    Last Post: 09-30-2015, 10:58 AM
  2. Replies: 1
    Last Post: 09-14-2015, 02:49 AM
  3. Is it possible to use a T-Mobile phone on a MVNO like WFM?
    Last Post: 09-12-2015, 01:31 PM
  4. How do I block emails to text on my T-Mobile S3?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 09-12-2015, 01:03 PM
  5. Why won't SpongeBob moves install on my Galaxy Note 4?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 09-12-2015, 01:02 PM
