1. tfou79's Avatar
    My AT&T Note 5 is acting up. It takes a while for pictures (Google+, Facebook) to load and even Chrome loads very slow. The signal bars seem to be all over the place and I usually see 1 or 2.
    Do any of you have the same issue? Were you able to fix it?
    09-12-2015 06:03 PM
  2. double923's Avatar
    I don't experience nor see the issue you described. All apps I used are very snappy. It could potentially be the area you were at where the tower might be congested. Do see the issue all the time? Do you know if you dropped down to non LTE connection?
    Sent from my SM-T810 using Tapatalk
    09-12-2015 07:50 PM
  3. Therealm80's Avatar
    Try closing the app fully and reopening it.
    09-12-2015 09:38 PM
  1. Replies: 6
    Last Post: 09-19-2015, 12:43 PM
  2. Note Edge finger print scanner won't work.
    By Stratostrophic in forum Ask a Question
    Last Post: 09-12-2015, 06:01 PM
  3. Do I need a new battery for my S4?
    By tea ptskialadze in forum Samsung Galaxy S4
    Last Post: 09-12-2015, 05:46 PM
  4. What happens if you are blocked on a samsung galaxy s5?
    Last Post: 09-12-2015, 05:10 PM
  5. Replies: 1
    Last Post: 09-12-2015, 04:19 PM
