12-06-2015 03:07 PM
33 12
tools
  1. 2015Mustangturbo's Avatar
    Any trick to get to work with a case on or is it not going to happen?
    09-13-2015 04:30 PM
  2. mhunter6378's Avatar
    Talking about this one?
    I use it every day, my Note 5 is in an Otterbox Defender and it works perfectly.
    stanleybb50 likes this.
    09-13-2015 04:35 PM
  3. felloffthetruck's Avatar
    Spigen completely stole this design from the TYLT VU.
    09-13-2015 04:44 PM
  4. 2015Mustangturbo's Avatar
    09-13-2015 05:03 PM
  5. mhunter6378's Avatar
    Check to be sure that you're using a 2A wall adapter, anything less will cause problems. Mine will only connect in the upright position, lay the phone horizontal and it doesn't connect.
    09-13-2015 05:08 PM
  6. mhunter6378's Avatar
    Yep but it works good and is cheaper. Although, it doesn't come with an ac wall adapter while the Tylt does so there's that added cost if you don't have one.
    09-13-2015 05:12 PM
  7. zeuswsu's Avatar
    What case are you using? Charges fine using a speck grip case.
    Sent from my SM-N920V using Tapatalk
    09-13-2015 05:28 PM
  8. 2015Mustangturbo's Avatar
    Spigen slim Armour
    09-13-2015 05:31 PM
  9. stanleybb50's Avatar
    Works flawlessly for my note 5. I'm using a 2 amp charger with it.
    09-13-2015 05:51 PM
  10. mhunter6378's Avatar
    Spigen slim Armour
    Doesn't that case have a metal kickstand? Wonder if that is interfering with the wireless charge connection...
    09-13-2015 05:54 PM
  11. 2015Mustangturbo's Avatar
    Yea could be
    09-13-2015 06:36 PM
  12. walhalla's Avatar
    Using a Ringke with mine. Works like a charm. Take it off in the mornings, at 100% and the phone is very cool.
    09-13-2015 07:07 PM
  13. Carl Bloom's Avatar
    So the N5 doesn't get hot at all with this charger? How long does it take to charge? Thanks.
    09-13-2015 07:44 PM
  14. matchtrader2000's Avatar
    Been using this one for a couple of weeks now. Works flawlessly, in either vertical or horizontal position. Seems to charge reasonably quickly too using the Samsung OEM quick charge plug.
    09-15-2015 12:45 PM
  15. pool_shark's Avatar
    I just received my charger, it doesn't work with my case but the Samsung puck does.
    09-15-2015 02:53 PM
  16. Carl Bloom's Avatar
    What kind of case do you have? Does it not work with any case out there?
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    09-15-2015 03:05 PM
  17. pool_shark's Avatar
    I'm currently using this one.
    Galaxy Note 5 Case, ENGIVE Dual Layer Hybrid Armor Full Body Protective Case with Kickstand and Removable Holster Swivel Belt Clip for Samsung Galaxy Note 5 (Black) https://www.amazon.com/dp/B013QBG6HK...cUvbUpU4686164
    09-15-2015 03:14 PM
  18. Jay G63's Avatar
    I don't think that case would work with any wireless charger.
    Sent from my SM-N920P using Tapatalk
    09-15-2015 04:07 PM
  19. rustypixel's Avatar
    Not to highjack the thread but can anyone that has the Spigen charger and a Note 5 tell me how the two get along? I have read a few scattered posts that it works but there have been issues getting it to charge in portrait mode. Just want to make sure before I get it.
    Thanks.
    09-15-2015 05:12 PM
  20. pool_shark's Avatar
    You must have missed where I said it it works with the Samsung charger.
    09-15-2015 05:39 PM
  21. pool_shark's Avatar
    Thanks.
    When I removed my case it was charging vertically and horizontally.
    09-15-2015 05:40 PM
  22. Jay G63's Avatar
    Hmm i must of. Have my own spigen coming in tomorrow. I have the otterbox commuter case. Poster on here says his works on defender so commuter should as well.
    09-15-2015 06:30 PM
  23. zeuswsu's Avatar
    Thanks.
    I charge my note 5 every night in portrait mode and have zero problems. With a speck candyshell grip case on.
    09-15-2015 06:38 PM
  24. Jay G63's Avatar
    Little disappointed. Got home from work, wife had new spigen wireless charger sitting on table waiting for me to unbox. Grabbed a 2 amp connector, plugged it in, charger lit up red, put phone on charger with case, nothing. Tried every position imaginable still nothing. Removed case, bingo. Not thrilled with having to remove the case every night but I probably will.
    Love the design just wish user results were the same across the board. I even took the outer case off commuter and just left rubber piece on and still got no response. Definitely going have to go naked using this one. Glad i have my white samsung puck to use where this new one was originally going to go.
    09-16-2015 03:45 PM
  25. pool_shark's Avatar
    I'm sending mine back. It won't even charge using the thin case I have, so my girlfriend won't even be able to use it with her S6 she bought yesterday.
    09-16-2015 04:46 PM
33 12
  1. Can I use my republic wireless Moto x 2 with AT&T?
    By AC Question in forum Moto X (2014)
    Last Post: 11-03-2015, 03:37 PM
  2. Beats Powerbeats2 Wireless
    By fofjjsr in forum Marketplace Archive
    Last Post: 09-24-2015, 12:36 AM
  3. Anker Quick Charge chargers
    By streetkilln in forum Moto X Pure Edition
    Last Post: 09-13-2015, 05:46 PM
  4. It is safe to use magnetic charger for Z2- D6503 ?
    By RohanD6503 in forum Sony Xperia Z2
    Last Post: 09-13-2015, 11:49 AM
