1. sirCLD's Avatar
    After playing around with several wireless chargers (except for the Fast Wireless charger) and not finding one that works, I did find that if my phone is above 50%, it will charge consistently up to 100%! I wonder if this has to do with the fast wireless charging from 0-50% and regular wireless chargers? I have tested every cheap (I have several from eBay that are old!!) and the Samsung puck, and found that below 50%, I cannot get a consistent charge: 'wireless charging paused' or it simply stops charging. But I just put my Note 5 on the cheapest wireless charger I have ever bought to test my theory again (I paid maybe $2 for it) and it was at 72%, it is now at 96% and still charging. I am also using a regular charging cable, not the adaptive fast charging cable. Anyone else have a similar experience?
    09-14-2015 11:21 AM
  2. beh's Avatar
    If the wireless charger doesn't output at least 1A you will have issues. You also need a 2A output wall charger if the wireless charger pad doesn't come with a wall charger. This isn't a phone problem or even a battery problem it is most often caused by wireless chargers having to low an output amperage.
    09-14-2015 11:31 AM
  3. pool_shark's Avatar
    I use the Samsung one that came free at best buy.
    My Note 5 has yet to be below 50%. The only time it will charge without disruption is if daydream is enabled.
    09-14-2015 12:16 PM
  4. 8100User's Avatar
    I convinced Verizon to give me their Qi Charger, which stands the phone up while charging, and it works great! No loud beeps, no issues any time I put it on the charger.
    I also use another qi charger downstairs in our house, and it also works flawlessly... don't even have to place it carefully on the puck (it's a round disk charger, that you simply lay the Note 5 down on), it chargers every time, and charges very quickly!
    I would think the issue may be with the chargers you're using....
    09-14-2015 01:30 PM
  5. beh's Avatar
    If it is the black color model given free by BestBuy it has a known fault and will not properly charge the Note 5. Samsung is replacing them if you contact them. And BestBuy will replace it with a different brand that will work if you take it back.
    pool_shark likes this.
    09-14-2015 02:55 PM
  6. pool_shark's Avatar
    Really? Good to know.
    09-14-2015 03:39 PM
  7. sirCLD's Avatar
    Interesting points... Thanks everyone! I have tried two Samsung hockey pucks, one samsung flat squared charging pad, 3 small round hockey puck style pads I bought from ebay, and one large rectangular one, and they all seem to behave the same way. And I've tried them all with a variety of plugs/cables including the fast charger that came with my phone. Now I'm starting to wonder if the issues with my phone itself...
    09-14-2015 10:36 PM
  8. Misterb's Avatar
    It's not the phone, and it isn't the charging cables, because both of those models you mentioned come with a cable and plug. It's the stupid Samsung charger itself. I've been thorough the whole problem with multiple returns and such. Finally said screw it and traded for a TYLT one, and it works perfectly.
    sirCLD likes this.
    09-17-2015 04:22 PM
  9. amandaw33's Avatar
    I'm having this issue on my Galaxy S6 on Tylt vu charger. If battery is 70% when I put it on the Vu, it charges to 100%, no problem. I'm not sure if my cut off is 50%, but I know at 40% it doesn't charge properly. Vu charger blinks red, then green, seems to pause charging and restart it over and over.
    12-08-2015 02:21 PM
  1. Replies: 3
    Last Post: 01-01-2016, 01:14 PM
  2. Wireless charging with protective case?
    Last Post: 09-14-2015, 02:57 PM
  3. Replies: 1
    Last Post: 09-14-2015, 01:57 PM
  4. Replies: 1
    Last Post: 09-14-2015, 09:49 AM
  5. Which Samsung Galaxy S5 will work in Greece?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 09-14-2015, 07:44 AM
