1. assmodius's Avatar
    Got a new 64 Gb Note 5 from Verizon yesterday and today it's been bleeding juice while locked.
    Adding a screenshot of my battery usage.
    Help?
    Attached Thumbnails Why is Cell Standby using the majority of my battery?-cell-services.jpg
    09-18-2015 10:15 PM
  2. thathybrid's Avatar
    Disable VoLTE or HD calling
    09-18-2015 11:04 PM
  3. dpham00's Avatar
    Install gsam. It looks from the screen shot that you have a weak signal which could cause high cell drainage
    Sent from my Verizon Samsung Galaxy Note 5
    09-19-2015 01:08 AM
  4. vm81's Avatar
    Help?
    I haven't seen your screen shot but can tell you that nothing will work... I mean you can disable all you want... It won't work. As long as you have WiFi on... It will drain your battery. Hopefully Verizon will fix this... But for now you can disable all you want... Nothing will help.
    babygirl0419 likes this.
    09-19-2015 01:25 AM
  5. jlilnc14's Avatar
    Help?
    I had the same thing happened on my Verizon note 5. I had to return it for a new one. Now it's not that high but still shows cell standby. A lot better.
    09-19-2015 12:27 PM
  6. Almeuit's Avatar
    Mod Note - Some posts have been cleaned. If you have nothing constructive to say please just move on.
    Thanks.
    vm81, hades8921 and dpham00 like this.
    09-19-2015 12:32 PM
  7. tripjnj's Avatar
    I got the same phone from Verizon about 3 weeks ago and had similar issues at first. Note that the problem is on WIFI only. I am not sure why, but for some reason it seems to have diminished over time. Looking at it right now after being on WIFI in my house for about 6 hours, cell standby is at 3%. It used to hover around 25-30%. My cell signal at the moment is hovering between 2-3 bars. Your screenshot shows only 1 bar, so that could be the issue.
    I tried disabling HD calling and that didn't make any difference so now I keep it on. You can't be on a call and use data at the same time if you don't have it enabled!
    Another thing I did was follow the De-bloating thread on XDA forums. Installing Package Disabler Pro and disabling a bunch of bloat has increased batter life, and who knows, maybe helped with this standby as well.
    vm81 likes this.
    09-19-2015 12:55 PM
  8. badkitties's Avatar
    how does one disable VoLTE on the Verizon Note 5?
    09-19-2015 01:06 PM
  9. carraser891's Avatar
    I have advanced calling on all the time and it uses less than 1 percent of my battery.
    vm81 likes this.
    09-19-2015 01:08 PM
  10. vm81's Avatar
    Go to settings and Advanced Calling...turn that off. Verizon calls its VoLTE Advanced Calling. However, if you turn it off...you will only be able to be on call or use data...not both.
    09-19-2015 01:16 PM
  1. Replies: 1
    Last Post: 09-19-2015, 12:59 AM
  2. How does the "ebooks" file work on an Asus memopad?
    By Heather Putnam in forum Ask a Question
    Last Post: 09-19-2015, 12:46 AM
  3. Two problems can not get warning sign off my phone
    Last Post: 09-19-2015, 12:43 AM
  4. Replies: 1
    Last Post: 09-18-2015, 09:49 PM
