1. mempto's Avatar
    So I know this is a dumb question, but I'm wondering if the note 5 always utilizes fast charging as long as the adaptive fast charger is used? I only ask bc sometimes the status says "fast charging" and sometimes the status simply says "charging" when I use the adaptive fast charger. Anyone know?
    09-19-2015 04:53 PM
  2. H3aTeRzz's Avatar
    It should always fast charge, if you have it checked "on" in settings. Now, if for some reason you use different cables, and or an outlet in your house/work is not putting out normal voltage, this, "I guess" could cause the inconsistencies in fast charge. This is just my opinion, anyway.
    09-19-2015 07:43 PM
  3. Jglasgow's Avatar
    I had my first experience with mine not fast charging yesterday, i thought maybe i didn't plug the cable in all of the way but it was when i tried to push it in more. I just unplugged it and plugged back in and haven't had an issue again. Not sure what could be causing this.
    09-19-2015 08:10 PM
  1. Does the new Snapchat update work on the Galaxy S5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 11-22-2015, 08:16 AM
  2. Note 5 Apps were stuck in landscape mode..........
    By felloffthetruck in forum Samsung Galaxy Note 5
    Last Post: 09-20-2015, 06:08 AM
  3. Replies: 0
    Last Post: 09-19-2015, 03:52 PM
  4. Galaxy S4: Battery draining fast and turning off??
    Last Post: 09-19-2015, 01:45 PM
  5. How long should my Samsung Galaxy S6 Edge charge for the first time?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 09-19-2015, 01:41 PM
