anon(9652351)
It came out ok
Sent from my Verizon Samsung Galaxy Note 5
Thanks to your help, really appreciate it. What I disabled looks ok? It sure did put them to sleep )
It came out ok
So long as your phone runs fine, no need to worryThanks to your help, really appreciate it. What I disabled looks ok? It sure did put them to sleep )
Re enable all packages, and see if it works again.
If you re-enable everything and the problem goes away, then you can disable them again one at a time until you figure out which one is the culprit.But, if I do that, how do I know which package it is that is making it work? I just want to know which package to enable leaving all my Custom ones disabled. That's the point of the app.
Is it a pain to have to do that? Yep.
But are there warnings that disabling things can have adverse effects? Also yep.
I figured. I wish there was an easier work around. Okay, I'll let you know.
*UPDATE, Enabled all disabled , Still didn't work. I don't even remember if opening the NFC Payment Setting worked after I did my factory reset a couple of days ago*
Everytime I try to run the NFC option in my Settings, Settings stops working. IS there a package in PDP that is not allowing me to run this setting? I have enabled NFC Service, NFC Test 1.3, Android Pay, all Settings have been enabled, but still Settings immediately stops working.
Why does it disable some Facbeook services/entries marking them as bloat? Which ones are really bloat?
So when marshmallow comes out I will need to re-enable everything in order to update Android?
This happened to me when I used the auto bloatware removal thing in Package Disabler Pro, it disables NFC and the service. Even if you manually enable it, you cannot access the options until you reboot your phone. Enable NFC then reboot the phone
Well you should enable all packages before updating to mm.
Keep in mind Samsung might patch the ability to disable packages...
With vzw they just push it^^ this is exactly why I will likely NOT upgrade to MM right away. I LOVE package disabler as it really does work and enables my Note to get HUGE and MASSIVE gains in battery life.
I did not re-enable the package disable pro before updating the system update .
So will my phone be not stabilized ?
