maskedcarrot
With vzw they just push it
Can't you just disable the firmware push service in PDP?
^^ this is exactly why I will likely NOT upgrade to MM right away. I LOVE package disabler as it really does work and enables my Note to get HUGE and MASSIVE gains in battery life.
Every update is promoted for all the wonderful things it does... then the reviews tell you about all the things they screw up.
Not sure what that has to do with M. There. Is nothing saying that M won't work with package disabler pro as of now.
Also M offers some features that might make package disabler pro unnecessary.
How is 'Package Disabler Pro', any better than simply disabling items via the Applications menu?
I tried doing some of the bloatware(pink ones) and some apps that I dont use.
I ended up with 10% battery drain upon sleep.
Is the app safe to use? If it can disable Knox and other more system level packages/processes, then seems like the app could have more access to other things like user data.
I see from the FAQ that the app does not have root access. Even so, how is it that an app can disable bloatware when natively we are only given limited disable or uninstall capability on Note 5s from carriers like Verizon?
Package Disabler – FAQ | OS Police
https://forums.androidcentral.com/e...olice.packagedisablerpro&hl=en&token=cNIFTEhH
