1. badkitties's Avatar
    (newbie question... just bought Note 5 today)
    what will happen to the Note 5 after more than 5 failed fingerprint scanning attempts?
    does it just start demanding that you enter the back-up password? how many times can you enter the wrong password?
    not that I'm going to attempt it or anything, of course. worst case scenario: what if I completely forget my back-up password and none of my fingerprints can be recognized for whatever reason? Does the phone become bricked?
    09-24-2015 01:38 AM
  2. tmp3150's Avatar
    The password is needed at that point.
    Posted via the Android Central App using the AT&T Note 5, 64GB
    09-24-2015 04:22 AM
  3. Nakrohtap's Avatar
    For some reason, I run into this only when I'm golfing. Not sure why that happens.
    I don't know if there's a limit for entering the wrong password, though.
    Sent from my SM-N920T using Tapatalk
    09-24-2015 05:24 AM
  4. drewood31601's Avatar
    If you forget your password, the phone then will allow you to log in with the Google email and password that is on the phone. Happened to me last night
    debdroid1a likes this.
    09-24-2015 05:31 AM
  5. JanShim's Avatar
    Fingerprint scanning doesn't work with sweaty fingers. Friends and I experience the same after hiking and badminton.
    09-24-2015 06:22 AM
  6. Delirious D's Avatar
    I dont think it works well with dry hands either. Lol.
    Sent using my gorgeous Korean Phone and its clicky stick...
    JanShim likes this.
    09-24-2015 06:57 AM
  7. DK Houston's Avatar
    Drewood, I hope you have the magic solution. I managed to hit the limit on fingerprint tries because my hands were dirty. I have two tries left on the password. I have tried my typical passwords. My last attempt was using my Gmail password, which I presume is stored in the phone, since it accesses my gmail account without any problem. What do you have to do, other than entering the password in the lock screen?
    12-20-2015 05:28 PM
  8. ninnjinn's Avatar
    I don't know exactly what all will happen, but I do know when you are setting your phone up you have the option after so many failed attempts it does a factory reset wipes everything out
    12-20-2015 08:08 PM
  9. russel5150's Avatar
    Whwn you set up the fingerprint it should have asked for a backup password.
    Depending on the setting, after too many wrong attemps it will factory reset your phone. I have that turned off, but i think it is on by default.
    Again, when u set up the fingerprints it should have made you pick a back up password
    Sent with my white Note5 with nonremovable back and no SDcard!
    12-20-2015 10:07 PM
  10. Mike_786's Avatar
    Okay guys I had a problem earlier with my password. So I got my finger print wrong multiple times which then told me to enter my password. I couldn't remember my password so it told me to retrieve my password by email. Now the problem was that I couldn't turn on my mobile data or wifi from the lock screen. Everytime I clicked the wifi or data toggle from the notification page nothing would happen. So how can I toggle wifi and data from the lockscreen?
    12-20-2015 10:50 PM
  11. russel5150's Avatar
    It wont let you if the screen is locked. Kind of a saftey feature...
    12-20-2015 11:12 PM
  12. EnemiesInTheEnd's Avatar
    If the fingerprint scan fails 5 times, the Note 5 begins to smoke then catch fire
    cjh1955 likes this.
    12-20-2015 11:58 PM
  13. badkitties's Avatar
    should I contact the IMF(Impossible Missions Force) for a replacement Note 5? my Note 5 doesn't start to smoke or catch fire or enter self-destruct mode after multiple failed fingerprint scanning attempts. I assume the agency should just give me a new Note 5 that will?
    wilmad likes this.
    12-25-2015 02:05 PM
  14. Alan FL's Avatar
    Granted, I'm a senior citizen, but I write down all my passwords and keep them in the same place.
    When I run into a need for them, I know where to find them (if I'm home that is).
    12-26-2015 09:41 AM
  15. bassplayrguy's Avatar
    Mine works great with dry fingers. Wet, forget about it.
    12-27-2015 03:25 PM
  16. Delirious D's Avatar
    I ment like none moisturized type of dry. Lol ashy..
    12-27-2015 03:27 PM
  17. milliman's Avatar
    I've been locked out more than once. Occasional clean off the fingerprint scanner because oils build up.
    12-27-2015 06:31 PM
  18. prolongExistence's Avatar
    On my s6edge I have had too many failed fingerprints. Then it asks for the Backup Password, which I forgot. So then it allows you to log in to your gmail account but you have to have internet access. Once you log into your gmail it will unlock your phone & the lock screen will now be disabled. In other words, it will revert back to the simple swipe to unlock. Then you just have to go back into the security settings and re-enable the fingerprint lock. My wife has the Note 5 but she doesn't like the fingerprint lock so I can't tell you for certain that it works the same way. I would imagine that it would, it's basically all the same software.
    12-29-2015 01:55 AM
  1. Productivity with note 5
    By desaiH in forum Samsung Galaxy Note 5
    Last Post: 04-09-2016, 11:16 AM
  2. What is for you the best pointn' click ever and why?
    By BearDroidGames in forum The Gamer's Lounge
    Last Post: 09-27-2015, 03:00 AM
  3. Replies: 1
    Last Post: 09-24-2015, 02:10 AM
  4. Cyanogenmod 12.1 failed on the galaxy s2
    Last Post: 09-24-2015, 12:53 AM
  5. Tried to install OTA updated on rooted Moto G2
    By Shankar Iyer in forum Moto G (2014)
    Last Post: 09-24-2015, 12:41 AM
