1. JanShim's Avatar
    I am using the stock keyboard and auto correct functions. Every time I enter someone's name Auto Replace thinks there's a match against Contacts and suggests their E-mail addresses as replacement. The E-mail takes up the entire rectangle and I have to tap on the arrow on the right side to ignore or look for other words to use. Is there a way to configure the Note not to ever look up contacts at all?
    10-01-2015 12:37 AM
  2. anon(153966)'s Avatar
    If you hold your finger down on it, are you presented with an ignore option or something?
    10-03-2015 06:14 AM
  3. JanShim's Avatar
    A 'Remove' pop-up screens asking if I want the learned word (in this case, an e-mail) "... will be removed from learned words." This method just means I would have to individually unlearn every (other) email it suggests.
    10-04-2015 06:50 PM
  1. Why the sudden shift from the 5x to 6p
    By mvasquez009 in forum Nexus 6P
    Last Post: 10-11-2015, 06:13 PM
  2. is my battery life good/bad? S6
    By Xthemasterxx in forum Samsung Galaxy S6
    Last Post: 10-03-2015, 05:59 AM
  3. Replies: 1
    Last Post: 10-01-2015, 03:12 PM
  4. Replacement battery for 1045xt
    By mydroidhere in forum Moto G (2013)
    Last Post: 10-01-2015, 12:06 AM
