1. OceanView's Avatar
    For some reason the signal bars on the note 5 is lower than on my note 4.
    I usually get 1 bar on the note 5 but in the same location I get 3 bars on the note 4.
    Have you guys noticed and signal issues on the note 5?
    10-01-2015 09:47 AM
  2. Kelly Kearns's Avatar
    You need to check the actual signal strength, not just the number of bars.
    10-01-2015 09:49 AM
  3. bassplayrguy's Avatar
    I have had no issues with mine compared to my Note 4.
    jimd1050 likes this.
    10-01-2015 01:51 PM
  4. Kelly Kearns's Avatar
    I just checked the signal in GSam on my Note 4 and Note 5 and my signal is the same.
    10-01-2015 01:59 PM
  5. jimd1050's Avatar
    Mine actually improved a bit from N4 to N5... checked it in several known locations too!
    10-01-2015 03:09 PM
  6. Almeuit's Avatar
    This. You would need to check the -dBm strength to see if it matches. The Cell Bars on each phone can be calculated differently -- which can make it looks like different signal strengths.
    10-01-2015 04:18 PM
  7. dpham00's Avatar
    Dbm and snr.
    Sent from my Verizon iPhone 6s Plus
    10-01-2015 04:48 PM
  1. Galaxy S5 WiFi issue's.
    By LURCHY845 in forum Ask a Question
    Last Post: 10-18-2015, 11:55 AM
  2. Is this supposed to be the G4 Pro?
    By cleankutazn in forum LG V10
    Last Post: 10-13-2015, 06:42 AM
  3. How is the speaker quality on the Nexus 5x?
    By AC Question in forum Nexus 5X
    Last Post: 10-01-2015, 07:00 PM
  4. Replies: 2
    Last Post: 10-01-2015, 10:35 AM
  5. Does the Nexus 5x support HDMI output?
    Last Post: 10-01-2015, 09:32 AM
