1. KiwiCoalBattery's Avatar
    who makes a Note 5 case with built-in MicroSD card slot? I remember reading something about it a while ago, but can't seem to find any info about it.
    Thanks!
    10-01-2015 12:20 PM
  2. trucky's Avatar
    Incipio has a battery & MicroSD case for the Galaxy S6. I would imagine the Note 5 might be on the list of those to come.
    Samsung Galaxy S6 Battery Case | Galaxy S6 Cases | Incipio
    debdroid1a likes this.
    10-01-2015 01:46 PM
  3. bplink95's Avatar
    Try one of these.
    http://forums.androidcentral.com/e?l...token=kRwTweN3
    10-01-2015 03:59 PM
  4. dpham00's Avatar
    No on atm.
    Sent from my Verizon iPhone 6s Plus
    10-01-2015 04:49 PM
  5. KiwiCoalBattery's Avatar
    No on atm.
    "probably never" is the answer that I got from Incipio. Their customer service rep emailed me back and said there was very little demand for the one they made for the S6.... so they have no plans to release one for the Note 5.
    10-03-2015 01:49 PM
  6. clankfu's Avatar
    Are there any available now?
    12-15-2016 07:29 PM
  7. Jude526's Avatar
    Get the Meenova Dash Micro SD reader
    12-15-2016 08:59 PM
  8. pteezay's Avatar
    Thanks!
    Why get a case when you can pick up one of these?
    SanDisk Ultra 128GB Dual USB Drive 3.0 (SDDD2-128G-G46)
    https://www.amazon.com/SanDisk-Ultra-128GB-Drive-SDDD2-128G-G46/dp/B019FN63OO/ref=sr_1_1?s=pc&ie=UTF8&qid=1482250893&sr=1-1&keywords=Micro+dual+storage
    12-20-2016 10:18 AM
  9. oditius's Avatar
    But you can lose that very easy. I wish they made a case, but no such luck...
    12-20-2016 08:25 PM
  10. SlimShadySkip's Avatar
    the only problem with this option (I have a few of these) Is that my Headphones are Digital Headphones with a built in DAC & Amplifier. Therefore since what I mainly need the Extra Storage for is "Music" It will not work as I can not plug both in at the same time....
    Solutions?
    PS: I do have 100gb Cloud storage thru Google Drive and have all my music on there. But I am yet to find a "Cloud Music Player" that actually works well and lets u que up several songs at once or play a Playlist. Any suggestions?
    SlimShadySkip
    Phx, Az
    01-17-2017 06:55 PM
  11. ratsttam's Avatar
    Believe it or not, but our friends at Microsoft support exactly this, although using OneDrive as the cloud source... Personally, I have Pandora + and that now caches the 4 most listened to stations for "offline" listening.
    https://play.google.com/store/apps/d...soft.xboxmusic
    01-18-2017 01:31 AM
  12. levjaskulski's Avatar
    I will recommend the I-blades modular case. You are getting extra battery, 64GB memory and accordint to them, a whole bunch of posiibilities. You can use the add ons when you need them, when you don't have the need, detach them, use as many you want at the same time, use special air quality sensors, VR sets etc. They are an interesting start up, I am quite fond that I saw the concept of the ARA is not dead. It is not a modular phone, yet a modular case. Quite nice
    02-07-2017 05:12 AM
  1. I can't make outgoing calls on my galaxy note 5
    By lori2lopez2121 in forum Ask a Question
    Last Post: 10-14-2015, 04:40 PM
  2. Replies: 38
    Last Post: 10-11-2015, 11:02 PM
  3. WTF was andriod thinking with Lollypop Update?
    Last Post: 10-01-2015, 02:23 PM
  4. Comprehensive SD card backup solution which doesn't miss files?
    By bingojeeves in forum General Help and How To
    Last Post: 10-01-2015, 12:00 PM
  5. How to save to SD card
    Last Post: 10-01-2015, 11:37 AM
