1. KiwiCoalBattery's Avatar
    Does using Android Pay, Apple Pay, or Samsung Pay cause shorter battery lifer?
    I currently have NFC off at all times...
    10-04-2015 08:00 PM
  2. zmann's Avatar
    You do not need nfc on to use Samsung pay,, the other 2 you do.
    Note 5 is DOPE
    10-04-2015 08:04 PM
  3. mfprince's Avatar
    No.
    zmann likes this.
    10-04-2015 08:22 PM
  4. KiwiCoalBattery's Avatar
    Note 5 is DOPE
    wait a sec, why doesn't the Samsung Pay need NFC on?
    10-04-2015 11:10 PM
  5. Glock23-G4's Avatar
    Because its advantage is that while it will work with Near Field Communication (NFC), it primarily uses Magnetic Secure Transmission (MST), which simulates a card swipe and transmits the data contained in the magnetic strip on your card.
    Apple and Android pay rely on NFC only.
    10-04-2015 11:55 PM
  6. r56mcs's Avatar
    I leave my nfc off too. I exclusively use mst.
    10-04-2015 11:58 PM
  1. Extra Battery?
    By Jeffk23 in forum LG G4
    Last Post: 10-05-2015, 09:54 PM
  2. Can I run stock Android OS on my Galaxy S6 edge+?
    By Matrix Leader in forum Android 5.0 Lollipop
    Last Post: 10-05-2015, 03:16 AM
  3. Google Play Store says it's stopped and so does my gmail
    Last Post: 10-04-2015, 07:34 PM
  4. Anyone using Wakevoice?
    By Inspgadget113 in forum LG G4
    Last Post: 10-04-2015, 06:43 PM
  5. Replies: 0
    Last Post: 10-04-2015, 06:30 PM
