1. iagoshick's Avatar
    I've been noticing my Note 5's power button is getting really soft and has no tactile feeling anymore, almost to the point where it is hard to determine if I pressed the button or not. I'm guessing this is not normal and the phone needs repair?
    10-05-2015 04:23 AM
  2. ramiss's Avatar
    You are correct, this is not normal.
    Sent from my SM-N920V using Tapatalk
    10-05-2015 10:49 AM
  3. JonnyDeLaSanta's Avatar
    I went to T-Mobile and they said they couldn't replace it until it was messing with my phone
    10-05-2015 12:02 PM
  4. ramiss's Avatar
    The moment you press the button and it doesn't do what you want it is messing with your phone.
    ShaggyKids likes this.
    10-05-2015 01:48 PM
  5. iagoshick's Avatar
    I'm gathering that your Note5 has the same issue as mine?
    10-05-2015 03:58 PM
  6. Ngannguyen's Avatar
    Yes, mine is too. So what did you do to repair? I bring my phone to the shop but they refused bcoz it's not actually can-not-work. It works but, as you told, too soft >"<
    10-19-2015 01:44 AM
  7. Jayden Watts's Avatar
    I too have this problem. Any fixes? What have you done?
    12-15-2015 02:21 AM
  8. PP763's Avatar
    Mine has gained a double click but only sometimes
    12-15-2015 04:08 AM
  9. Dhawk1202's Avatar
    Yes, mine also goes soft then clicky throughout the day.
    12-15-2015 08:49 AM
  10. sergiu.m's Avatar
    Mine also did it a few days after i've bought it, it sort of fixed itself afterwards.
    12-15-2015 11:06 AM
  11. linkiik121's Avatar
    It happened to me with the volume button. I sprayed windex on a tissue wiped around the button. Pressed it a few times, some more wiping with my nail pushing the damp tissue around the button. Dried it and that fixed the problem.
    Posted via Note 5 64GB AT&T
    12-15-2015 11:59 AM
  12. Hussein Mohammad's Avatar
    same problem happened to my new galaxy note 5 only after 2 weeks of use
    02-10-2016 05:34 AM
  13. Ladelfm's Avatar
    This solved my issue, Thanks!
    02-10-2016 08:55 AM
  14. usman khushnood's Avatar
    Clicky issue can be fixed by rubbing any alcohol wipe on it. My home button got very loud abd used to make an annoying clicky sound. So i took a micro fibre cloth and sprayed sme perfume on it and rubbed it on n around the home button and its back to normal.
    02-10-2016 09:35 AM
  15. beh's Avatar
    give your phone a "blue pill" I be bad!
    02-10-2016 01:02 PM
  1. Replies: 1
    Last Post: 10-06-2015, 12:59 AM
  2. Why aren't messages sending on my Samsung mobile?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 10-05-2015, 04:17 AM
  3. 5.1.1 software update is driving my battery crazy why?
    Last Post: 10-05-2015, 04:06 AM
  4. Why does my Google Voice to text screen get stuckft
    Last Post: 10-05-2015, 03:40 AM
  5. Replies: 1
    Last Post: 10-05-2015, 03:03 AM
