1. KiwiCoalBattery's Avatar
    Do all Verizon Note 5 rear cameras have the Sony sensor? (as reported by the AIDA64 app)
    Thanks!
    10-07-2015 12:34 AM
  2. dpham00's Avatar
    Mine does.
    Sent from my Verizon Samsung Galaxy Note 5
    10-07-2015 10:29 AM
  3. Nakrohtap's Avatar
    I think there is another thread for this question. There is some kind of setting you can put in your phone that will tell you what sensor you have. Search the threads.
    Sent from my SM-N920T using Tapatalk
    10-07-2015 12:38 PM
  4. KiwiCoalBattery's Avatar
    all you have to do is go to Google Play Store and install AIDA64 app. It will instantly tell you what kind of sensors are used in the Note 5's front and rear cameras.... for all three of my Verizon Note 5 phones, all have Sony sensors for the rear camera. (on the front selfie camera, they are all Samsung sensors)
    10-07-2015 01:18 PM
  1. How to update LG G3 d850 without being on the at&t Network?
    Last Post: 11-05-2015, 06:15 AM
  2. Why doesnt my Edge + charge on the Samsung Fast Charge Pad
    Last Post: 10-07-2015, 03:23 AM
  3. Note 3: Cant boot into recovery
    Last Post: 10-07-2015, 12:28 AM
  4. NOT able to call extension after lollipop upgrade note 3
    Last Post: 10-07-2015, 12:06 AM
  5. speaker on note 3 isnt loud
    Last Post: 10-06-2015, 10:56 PM
