1. maskedcarrot's Avatar
    I have a Verizon Note 5 for work and just recently got an AT&T Note 5 for personal use, and find there are some differences.
    1) I like the sounds / ringtones on the Verizon model better.
    2) I like the settings menu that scrolls vertically on the Verizon model, I hate the AT&T side scrolling settings menu. (Anyway to change?)
    3) The AT&T version seems to get a little bit warm when using. Hadn't noticed that on the Verizon Note 5. (worries me a little)
    4) AT&T Note has way more bloat than the Verizon.
    5) Probably my imagination, but the Verizon Note seems snappier than the AT&T Note.
    6) AT&T has Samsung Pay. Just set it up and ordered my free wireless charging pad.
    Those are just a few purely personal observations between the two. Does anyone else's AT&T Note 5 get a little warm when using? I'm not saying hot, just warm. My Verizon Note 5 hardly changes temp at all.
    I can't wait to use Samsung Pay and try it out. I've read the articles that say Verizon will get it. But who knows when. Plus I wanted my free wireless charger. I had to get it done before the deadline.
    mari dub likes this.
    10-08-2015 12:00 AM
  2. Ruben Ocasio's Avatar
    Nope never got warm as you speak on my AT&T Note 5
    jimd1050 likes this.
    10-08-2015 05:46 AM
  3. bassplayrguy's Avatar
    I am on ATT and mine does not get warm.
    10-08-2015 06:21 AM
  4. MDMcAtee's Avatar
    Nope no change in temperature on mine.
    Posted from my AT&T 64 gig Black Sapphire leather wrapped Note 5
    10-08-2015 06:56 AM
  5. Davenurse's Avatar
    None here either
    Posted from the most awesome phone on Earth Galaxy Note 5
    10-08-2015 08:38 AM
  6. athomas917's Avatar
    Att is notorious for bloatware. As far as sounds, you can download any other carriers ringtones. I have apple and blackberry tones on mine.
    10-08-2015 09:27 AM
  7. maskedcarrot's Avatar
    Well I went and exchanged mine this morning to be on the safe side.
    Also one other thing I noticed which was different. If the phone is off, and you plug it in, on the Verizon Note 5 you will tell you that it's fast charging, and how much longer it will take to be at full charge.
    On the AT&T Note, all it shows is the percent, and a lightening bolt. I like that the Verizon one gives you more info on the charging.
    I can understand that different carriers might want to change a few things, but why change simple things like that?
    10-08-2015 10:13 AM
  8. Davenurse's Avatar
    Error
    10-08-2015 10:19 AM
  9. Katrina White1's Avatar
    You're getting some janky ATT phones or something. Mine doesn't get hot and shows the amount of time to get to 100.
    At&t Note5
    10-08-2015 01:26 PM
  10. Glock23-G4's Avatar
    At&t Note5
    Even when the phone is off?
    10-08-2015 01:48 PM
  11. Katrina White1's Avatar
    Apologies. I missed that part. If I'm not mistaken, when the phone is off, it shows the present percentage, but no remaining time to 100.
    At&t Note5
    10-08-2015 09:56 PM
  1. Use of two devices paired at the same time.
    Last Post: 09-29-2016, 04:25 PM
  2. How do I open my booted phone?
    Last Post: 10-07-2015, 11:18 PM
  3. Auto brighness on Note 5 has changed sensitivity
    Last Post: 10-07-2015, 10:58 PM
  4. Replies: 0
    Last Post: 10-07-2015, 10:44 PM
  5. Replies: 1
    Last Post: 10-07-2015, 10:35 PM
