1. ctychick's Avatar
    Haven't tried Samsung Pay yet, I'll take a pass if it only works if the phone is naked. Thanks.
    10-08-2015 02:11 PM
  2. me23brown's Avatar
    Well it worked for me with a case, but its a small one from Best Buy. I'm not sure about the large ones like Otterbox.
    ctychick likes this.
    10-08-2015 02:14 PM
  3. Glock23-G4's Avatar
    Works fine with Otterbox, Pelican, etc...
    10-08-2015 02:22 PM
  4. ReggieReg72's Avatar
    I have a ghostek slim case and it works for me.
    10-08-2015 04:23 PM
  5. double923's Avatar
    Works fine for me.
    10-08-2015 04:57 PM
  6. wookiee2cu's Avatar
    I used Samsung Pay for the first time yesterday and I have a slim Tech21 case that I got from T-mobile without any issues.
    10-08-2015 05:21 PM
  7. zmann's Avatar
    Yes it does
    Note 5 is DOPE
    10-08-2015 05:34 PM
  8. jmy7213's Avatar
    Most cases I have it works fine. I have found that cases with magnetic kickstands on them screw it up a lil when using the MST side of it. But as long as it does not have a magnetic back, I've experienced no problems with Samsung Pay.
    Sent from my Samsung Galaxy Note V
    10-08-2015 08:23 PM
  9. OceanView's Avatar
    Yes it does. I use my Dztronic case with it with no issues.
    10-08-2015 09:34 PM
  10. TheDonJ77's Avatar
    No issues with my UAG Maverick case :-)
    yarnsrj likes this.
    10-08-2015 10:11 PM
  11. smooth4lyfe's Avatar
    Works perfectly with my Spigen Ultra Hybrid case
    10-08-2015 10:18 PM
  12. racedog's Avatar
    My wife has a Mophi Juice case. She hasn't used it yet with SP but I'm betting it isn't going to work because the entire back is battery.
    10-09-2015 12:28 AM
  13. anon(26204)'s Avatar
    Do u have the Tech 21 Flip Case? Is that the case used it with?
    10-10-2015 10:31 AM
  14. Jamez Avila's Avatar
    Same here. Used Samsung Pay numerous times with my Dztronic case with no issues.
    Posted from my Galaxy Note 5
    10-11-2015 12:57 PM
  15. Jeff0575's Avatar
    Do not buy an otterbox defender for the s7 edge if you want to use samsung pay or wireless charging. Will not work.
    07-19-2016 02:47 PM
  16. amyf27's Avatar
    For me it has worked with my Otterbox Commuter case and with a clear gel case. Sometimes depending on the terminal I'll take the case off and it works better
    07-19-2016 02:55 PM
  17. Rmbrown1964's Avatar
    Works for me, I have a spider case
    07-19-2016 04:20 PM
  18. jregan68's Avatar
    Works fine for me with otterbox defender and commuter.
    jimd1050 and yarnsrj like this.
    07-20-2016 07:13 AM
  19. Almeuit's Avatar
    Yep .
    jimd1050 likes this.
    07-20-2016 07:51 AM
  20. bassplayrguy's Avatar
    Works for me in a case
    07-22-2016 04:59 PM
  21. patmcglynn72's Avatar
    I'm about to buy the s8 today with the Samsung brand wallet LED case, does anyone know if android or Samsung pay works with that case? Thanks..
    05-03-2017 08:21 AM
  22. jlost's Avatar
    Yes. I had a leather case on mine and used it
    05-03-2017 06:59 PM
  1. if you have the UAG case for your Note5, have you ever dropped it?
    By KiwiCoalBattery in forum Samsung Galaxy Note 5
    Last Post: 03-29-2016, 10:05 AM
  2. A questions on Samsung Pay
    By Stanfna in forum Samsung Pay
    Last Post: 10-11-2015, 10:05 AM
  3. Does this look like normal Lollipop 5.0 Battery life?
    By chadhindsley in forum Batteries
    Last Post: 10-08-2015, 02:05 PM
  4. Replies: 0
    Last Post: 10-08-2015, 01:09 PM
  5. samsung lgl34c boots up then shuts off?
    Last Post: 10-08-2015, 01:07 PM
