1. Blues Fan's Avatar
    So I've been having Bluetooth on a lot since I bought the Gear 2s and I've notice that the battery has been draining faster.
    Is this typical? Has anyone else been having this problem?
    10-10-2015 01:47 AM
  2. athomas917's Avatar
    Yes, this is normal for all phones when using Bluetooth. You should have it off when not in actual use.
    10-10-2015 02:44 AM
  3. vlfifthdawnlv's Avatar
    Is bluetooth actually showing up on your battery usage? Modern bluetooth us very little battery. It should add up to less than 2% of your usage. A lot of times, its really just in your head.
    10-10-2015 03:56 AM
  1. My HTC 620G DS is not getting Charged when it s switched On
    Last Post: 10-31-2015, 08:00 AM
  2. Sudden battery drain... Please help!
    By Mariah Richardson in forum Samsung Galaxy Note 5
    Last Post: 10-11-2015, 07:46 AM
  3. How to turn off running apps on lg optima 90
    Last Post: 10-10-2015, 01:09 AM
  4. Replies: 0
    Last Post: 10-10-2015, 12:40 AM
  5. Replies: 0
    Last Post: 10-10-2015, 12:27 AM
