bassplayrguy
Trusted Member
I wish ATT didn't disable this feature.Another feature I like is download booster.View attachment 201100
I'm not sure why carriers are disabling these features. It's one of the reasons I'm sticking with T-mobile. They don't disable awesome features, the bloat is minimal, no carrier branding, unlimited data, and upgrade every year.I wish ATT didn't disable this feature.
I was on Tmobile for a long time and never had any complaints until I moved out of their coverage area.I'm not sure why carriers are disabling these features. It's one of the reasons I'm sticking with T-mobile. They don't disable awesome features, the bloat is minimal, no carrier branding, unlimited data, and upgrade every year.
So far they are good. And it seems like the coverage area is expanding.I was on Tmobile for a long time and never had any complaints until I moved out of their coverage area.
One of my favorites widgets from the Note 4 is back and it looks like it received some refinement. The My Places widget allows you to create location based apps on your home screen and adjust user profile. For example, when I get into my car, I connect my Bluetooth and it automatically changes to my car settings with my car apps displayed. When I get to work, it automatically identifies my location through the GPS and turns on my WiFi to connect to my job's network, my volume is reduced to vibrate, and my work apps appear. When I'm at home it auto connects to my home wifi and I see the apps that I want to use at home.
You can schedule a phone restart.
Mine is a Verizon model. Probably correct about not having it in Nova. I found it in Touchwiz in the widget drawer, I originally had it disabled via Package Disabler Pro, doh!
But like I said I hardly ever use location unless I'm navigating, but good to know the option is there and wasn't one of the things to add to the list of ways Verizon strips the phones.
^^This is great. What a great idea. But, I am curious looking at your screen image; how did you get the 2nd half - with the file names and the camera, T, and pen? Is that a different widget?
Is there such a thing as a carrier unlocked note 5?
How do you do that?
