1. Cl3arCh0ice's Avatar
    Heya!
    Wondering if anyone had any ideas. My 64gb Verizon Note 5 has issues with wifi. It seems to only happen after the device has been sleeping but what is happening is it stays connected to the wifi but will not pass traffic. A simple toggle off and on of the wifi fixes it. My access point shows that it never loses its connection and this only happens on the Note 5 and not any of the other devices on the network.
    I've tried:
    Factory Reset
    Forgetting the network and rejoining
    Made sure the settings to keep wifi active is set to always on
    10-13-2015 06:58 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! In the advanced wi-fi settings, is there an Wi-fi Optimization option? If so, turn it off (it's for battery saving, not to improve reception). Also try turning off Smart Network Switch, if present.
    10-13-2015 10:03 PM
  3. Cl3arCh0ice's Avatar
    Hey thanks for the reply!
    I do not have that option in advanced and smart switch is off already
    10-13-2015 10:13 PM
  4. Cl3arCh0ice's Avatar
    So i've been messing with it and watching it over the past few days and it seems to be random. I could leave it overnight and its fine but then let it sleep for 5 min and it shows it connected but it doesn't actually pass traffic
    10-17-2015 10:22 PM
  5. Miami1683's Avatar
    Is a known big on the vzw version, I'm hoping an update will fix it
    Sent from my SM-P900 using Tapatalk
    10-17-2015 10:42 PM
  6. Cl3arCh0ice's Avatar
    Thanks!! Now at least I can quit messing with it. Although it is a pain because I like to use air droid and when the connection goes sour it won't connect.
    10-18-2015 08:55 AM
  1. Replies: 11
    Last Post: 10-20-2015, 01:31 PM
  2. OK Google issues
    By ELAkid in forum Moto 360 (2015)
    Last Post: 10-15-2015, 05:36 PM
  3. S2 Plus RAM issues.
    By DragosMugurel in forum Ask a Question
    Last Post: 10-15-2015, 10:55 AM
  4. My firmware upgrade has encounter an issue, how can I fix it?
    By sainthau in forum Samsung Galaxy Tab 2
    Last Post: 10-13-2015, 05:06 PM
  5. Wifi connection issue
    Last Post: 10-13-2015, 04:15 PM
